Question about SanDisk Sansa e250 MP3 Player
Not picking up memory card
I put my 1 gb sandisk memory card in my sansa e250 and its not picking up whats on the memory card
Posted by taylorwithey on
  • taylorwithey Apr 15, 2009
    i dont have a slot in my computer for it...i need to get a usb adapter for it in order to do that.is that what i need to do is put the memory on the computer and copy it onto the mp3 player??the card was for my phone and it worked fine in there..
  • Anonymous May 11, 2010
    Have you tried the card in your computer?
Anonymous
    Problem Solver:
  • 5 Answers
This is what i did when i was having the same issuse with my 1GB memory stick too, that i was trying to get assess to using my Samsung F480. Instead of Formating the memory stick in the phone it self. Format the memory stick in a computer using the adapter that you get with it when purchased.
Posted on Apr 22, 2009
2answers
How do i add memory to my player. now it has 2 gb and i want to replace it with 16gb
You can't augment the internal memory, short of replacing the entire motherboard. And if you're going to take the innards out of another Sansa, why don't you just use that other Sansa instead?
You can add memory in 2GB chunks by using microSD cards. Photos and videos must be in the 2GB internal memory, but any music you put into a MUSIC folder on the card will appear and play on the Sansa. By putting different albums (or sets of albums) on different cards, you can easily switch between them.
Be sure you use microSD cards, not microSDHC cards.
How to expand my memory and what type of memory card to buy
It will certainly take a 2GB microSD card.
This link on Sandisk forums tells how to check if you have a version 2 that will take a 4GB.
forums.sandisk.com/t5/Sansa-e200-series/Sansa-e250-compatible-with-4-GB-Micro-SD-Card
Where to buy one? My local supermarket has them, or you could check a camera store, or even office supplies. as well as the usual computer or electronics stores.
Hiii, just wanted to know sansa e 250 's expandable memory can be expanded to how much GB.
You can put music on any as many microSD cards as you wish. Each microSD card will hold up to 2GB, as long as you put the files into a folder called "MUSIC." You can't put any photos or videos on the cards, however, only audios. And, of course, you can only have one card in the e250 at any one time, but you can swap them in and out.
Make sure you use microSD cards. The e-series will not use microSDHC cards.
1helpful
I have a Sansa e250 I have put a new Micro sd card with 8 gb memory into the card slot it has music loaded on to it ( when it is in the computer it comes up and shows what is on it ) the player does not...
The e-series uses microSD cards. Your 4GB card is actually a microSDHC card. While it fits into the slot it is not electronically compatible and will not work in the e250. You need to stay with microSD cards, 2GB and smaller.
The newer Fuze series will accept microSDHC cards.
2helpful
Can I attach an 8 GB Micro SD Card in the expansion slot of my Sansa e250? If not, what is the maximum storage size it supports?
The e250 uses microSD cards, not microSDHC cards. The maximum size of microSD cards is 2GB. Anything larger are microSDHC cards.
2answers
Is there a spot for a micro chip on the sansa e250
Yes it does have a slot for microSD card on the right side
Sansa mp3 player could not detect micro sd add on card
I believe you can fix it by going on the player, then to settings, then to USB mode, and switching it from MTP to MSC. If you're in MSC already and it fails to recognize, then I don't know. :(
More memory?
I haven't tried this, but I see no reason it why it shouldn't work. I have used an 2gb expansion card in my Sansa and it works just fine. The only problem is it will only play music off of an SD card, no video. I guess this is only to much memory if you don't need it. Rough guess is that a 4gb will hold roughly 1000 songs. I would only go for the smaller sd card if there was a substantial price difference and you won't be needing the extra space.
3helpful
5answers
4GB micro sd card.
According to what I've read, you can double the original memory, but no more than that, so the max you can have on a Sansa e250 would be 4 GB (2GB internal memory and 2GB external memory). I also read that the micro SD cards holds
music only-no video.
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Jean Sintulaire
Ekse
Daniel Dollive
Daniel Dollive
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
