Anonymous Posted on Apr 09, 2009
Never wired a stereo. need all details completed. electronic
I want surround sound please.
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
42
Points
I went t a support site that was FREE and reviewed a wiring schematic.
1helpful
2answers
Denon receiver not working surround output
If everything is connected correct, the only thing I can think of, is you don't put in a surround signal. If you only feed 2 way stereo, only two speaker will work. Also if you switch to stereo, the other channels will stop working. Check the cables, the settings and the input.
Marantz pm493 surround sound and tv
google search for the manual.
or
set the amp to all channel stereo or similar option so sound is set to come out of all speakers the same or in stereo as opposed to surround. See if it makes sound then if not check all connections etc, pull wires out and put then back in carefully
How do I hook up my surround sound system thru my stereo and tv
connecting your surround sound system is not complicated.things you may need:OLDER STEREO SURROUND SOUND:analog red, white, and yellow cable connectorsHDMIaudio fiber opticsif you bought your stuff new from electronics store,then it would be easier.all you need is HDMI cables (mostly)depending where your inputs and outputs go, you must know the rule. OUT-TO-IN. that means if you are using a cable box, dvd, bluray, playstation, or xbox. everything in these electronic devices are OUT. then connect them to the IN ports of your surround sound. at the back of your surround sound there will be connections saying IN-dvd, IN-dvr etc. connect your OUT DEVICES.
NOTE: YOU MUST KNOW WHAT ARE YOUR CONNECTIONS, LIKE DVD-IN OR DVR-IN CU'Z YOU WILL USE YOUR REMOTE TO CHOSE WHICH CONNECTIONS YOU WANT TO USE.
now from your surround sound to your tv.the same ruleout to in of your tv. You should look for HDMI port that is saying OUT. you will connect your HDMI cable from there connecting to your IN of your tv. remember which port you plugged the HDMI cable as you will switch to that particular input. it will say at the back of your tv in-1, in-2, in-3 or as much as the manufacturer want to have in there product.
connecting your speakers.you must remember the color code.if you chose red as positive, all the red wire must be positive.colour may be different but same idea. if you have sub-woofer it will be an analog cable you will only use single cable. At the back of your surround sound there's a connection saying sub-woofer out.
now selecting your inputs.turn on your tv and stereo.newer tvs and stereos are smart they can configure there system which is turned on.
anyways if you will do it manually, you must select from the remote what is the connected input. (input 1, input 2 etc.) if you found the right input, do the players (dvr, cable box, dvd, bluray, playstation, xbox etc) turn them all on and select from your stereo remote control.note all the inputs you selected.
I bought an rcrn04gr universal remote to run my kenwood home stereo but can't find the right code
Make a code search process. If there is any code programmed with your device, with remote control, you can access it.Visit this site for more details. Type in the site name "Electro-help" either Google or Yahoo search box [not in the address bar of your browser], and click search. It is an electronic equipments service help site. All details you want are there. Note the position of hyphen in between words in site name, when you type it in. The site will appear as it is in web; subtitled as service help to electronic home entertainement equipments.
Pull up older posts. You can get all details.
Check associated ads too. Sometimes, it might help you.
2answers
I can hear the music when playing dvd's on my Spectoniq dvd player, but can't hear when people talk. Can anyone help me?
Yes, I can help you. Your DVD player should have output connectors in the back of it to plug your amplifier or receiver into. If you have a Stereo system (no surround sound speakers, or front center speaker) connect the DVD Audio Cables on the back of the DVD player to the STEREO Output Jacks. If it is connected to the Left Front and Right Front jacks of the "Surround Sound" output jacks instead of Stereo is that the dialog on is sent to the CENTER channel output. If you have no center channel speaker you will not hear it.
If you have a surround sound system with two speakers in front and two speaker in back. Then you need to make a change in the Receiver Setup (Which may be set up for 3 speakers in front) so that it is set up for 2 speakers in front.
The last thing my simply be that you have a center channel front speaker that is not completely connected because of a wire falling off, etc.
Hope this helps,
Best,
Mark
How do I get my Aspire AX3910 to recognize my surround sound stereo via HDMI? My computer is only showing 2 channels. I need it to give me a surround sound option, yet it's only giving me stereo as my...
It would help if you use windows 7 ..cause it has the possibility to select the digital out on the sound settings .If you use xp ..you have to open the sound manager and click advanced ..and if it only have the stereo choice t measn the system is not capable to send info in other way ..via hdmi ..and choose stereo ..and select the surround on the tv ..if it is next in line for processing the signal .
Problem with surround sound on JVC Th-C5 sound system
Not sure how you're hooked up or what model TV you're using. If you mean the TV sound through RCA cables is the source and you're wondering why it's not surround. Well, it's not multichannel. Please fill in some details.
Samsung 5-Disc 1200-Watt Home Theater Surround Sound System My Home Theatre System is keeps shutting down by its self. before it shuts down the screen says protection mode and then shuts down. i have...
If the unit shuts down almost immediately without sound, you have an electronic failure of the audio amplifier.
However if you must play the unit up above quiet background levels, you likely have a shorted speaker wire. With home theater systems, you have the luxury of trying different surround modes and speaker level settings. It's not unusual, for example, to have a loose wire strand going to the center speaker. In stereo, the system works fine. As soon as you switch to a surround mode, the amplifier senses the short and shuts down to protect itself.
Check those wires really close - I bet you'll find it there.
How do i hook up Altec Lansing AVS500 speakers to my computer
Hello sweetnikki1,
The Altec Lansing AVS500 are 4.1 channel speakers, meaning 4 speakers (front, rear and 2 satellites) and a subwoofer.
1. Make sure the rear and/or center/sub audio cable is plugged in to the correct port. On most surround sound cards, the rear audio port is black, the front audio port is green, and the satellite cords are similarly color coded. The output from the sub to the front right satellite is a heavy-duty cable that immediately stands out from the rest. This cable is thicker because the right front speaker has most of the system controls on it: power, volume, and surround volume. If you do not have a surround sound card, make sure you obtain the proper adapter or use surround sound emulation if your speaker system offers it. If you are not sure if you have a surround sound card, please check with the manufacturer of your sound card for details.
2. Make sure your sound card supports the same amount of channels as your speaker system contains. For 4.1 systems, it should have a front and rear speaker jack on the card. The card should be properly installed and configured. Please contact your sound card manufacturer for details. If you do not have a surround sound capable sound card, on the left side are the sub level control, the AC jack, satellite outs, and a sound mode switch. With this switch you decide between Gaming and Stereo. In Stereo mode, the normal stereo signal is sent to both the fronts and the rears. In Gaming mode, the speakers use the four-channel signal from your soundcard. Hence if you just hav the regular sound card, do not connect the satellite speakers and use Stereo mode.
3. You can also use an adapter to split the signal for the front and rear speakers. This type of adapter is a 3.5mm male to 2-3.5mm female jacks. You can purchase this adapter at your local electronic store. Please refer to your manual if you do not know if your speaker system can emulate surround sound.
Hope this helps..
Should you have any further questions, please feel free to post them here. Please do not assign a rating until you feel your problem is resolved. I will try my best to help you further, if need be.
If you are satisfied with my solution or have no other questions, please close the problem by assigning a FixYa! rating for my solution. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Philips dvd sarround soud set up with pc
The cables you use are what come from the speakers, but you will need to have a dedicated 2.1, 3.1, 5.1 or 7.1 surround sound card fitted, you cant split the sound channels from a normal stereo analogue sound card.
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Ngoro
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
