Kenwood KDC-MP208 Car CD/ MP3 Player Logo
Posted on Apr 09, 2009
Kenwood KDC-MP208 Clock Set
Kenwood KDC-MP208
Can't set the clock.
Manual says to hold down the Bass Boost button until the Menu comes up, then hit the down adjust until "Clock Set" comes up. But, that menu option never comes up.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Sep 14, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
3836
Points
24
Make sure that the source is set to "Standby" when trying to access the menu. It took me about an hour to figure it out and afterward I felt like a ******.
  • 1 more comment
  • Anonymous Jun 13, 2013
    what is the source? and how do i remove the bass boost?
  • Anonymous Jul 21, 2017
    How do I get it to stop blinking once it is set....when I hit the B boost, the display says CLK ADJ. Is it set?
  • Charles Adams
    Charles Adams Aug 18, 2021
    Hold down the pause/play button until the clock appears. Then adjust with the up/down buttons.
1helpful
Downloaded manual for Kenwood KDC-MP528, but instructions for setting clock time is sketchy, and can't get " clock adj." to come up, no matter in what sequence I hit instructed buttons....
Try putting the radio in standby mode and then hold the menu button in for a few seconds. Once you enter the menu, use the am or fm buttons to scroll through the menu. Then hold the seek up or seek down for a few seconds until the clock flashes, You should then be able to use the am/fm buttons and seek up and down buttons to set the hours and minutes. Once you have the time set, press the menu button again.
How Do I Set My Clock on My Kenwood KDC-MP208?
1:- Select Clock Adjustment mode Press the top or bottom side of the Control knob. Select the "ClK ADJ"/ "ClCK" display. 2:- Enter Clock Adjust mode. Press the centre of the Control knob for at least 1 second. The clock display blinks. 3:- Adjust the hours. Press the top or bottom side of the Control knob. Adjust the minutes Press the right or left side of the Control knob. 4:- Exit Clock adjustment mode, Press the [B.BOOST] button.
Now whats the time, Gotta get my tea.
Regards, Dave
10helpful
How do I set the time on my Kenwood KDC-MP238 cd player
You will find the manual to your Kenwood KDC-MP238 at this link. The clock settings are found on page 10/11. However for a quick try on your own. Put the headunit on STANDBY then press B. Boost button for 1 second, that will take you into the menu. Select CLK ADJ, press the Control button on the right hand side of the headunit for 1 second. The clock display should start blinking. Now use: Control button up/down changes the hours. Control button left/right changes the minutes. When you set the time, press B.Boost button to exit.
http://www.kenwoodusa.com/Support/Car_Entertainment_Owners_Manuals/ select model from drop down list.
Good Luck
dreamsystems
10helpful
I can't set the clock on my kenwood kdc mp238 car stereo
In standby mode press and hold bass boost/menu button to open options menu. use direction pad to toggle thru options. push center button in middle of direction pad to enter each option for adjustments clock adj, etc...
5helpful
Set clock on kdc-mp208
Here's the owners manual for your KDS-MP20, from the kenwood-usa site:
http://kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kdcmp238.pdf
The following is found on pages 10 and 11 of the manual:
1. Enter Menu mode
Press the [B.BOOST] button for at least 1 second.
"MENU" is displayed
2. Select the menu item
"CLK ADJ" can only be performed when in Standby Mode
Manual Clock Adjustment
1. Select Clock Adjustment Mode
2. Press the center of the Control knob for at least 1 second
-the clock display blinks
3. Adjust the hours
Adjust the minutes
Press the left or right side of the Control knob.
4. Exit Clock adjustment mode
I hope that helps.
3helpful
How do i set the clock on my kenwood kdc-mp5032?
press the menu button for a few seconds until the menu comes up, then using the am or fm buttons scroll until you reach clock, then press either the seek up or down button untill display flashes. then press the am/fm buttons to set hour and seek up or down to set minutes. when finished just press the menu button againl.
How to set the clock
there should be a button labeled menu. press this button for a few seconds and it should take you into menu mode. use the fm/am buttons to scroll through the menu until ;you reach clock, the press the seek up or down button until the display starts flashing. use the am/fm and seek buttons to set the hour and minutes. press the menu button again to leave the menu.
5helpful
SET THE CLOCK ON KDC-MP435U
Press menu button and use volume button click up or down until CLOCK ADJ comes up and Press and Hold down DISPLAY button clock should blinking use volume control button click it up or down for Hour and side to side for mins.
I recently purchased a kenwood KDC-MP208 and am having difficulty setting it to display the time.
First, set the clock if it isn't already set. You need to get your cd player into standby mode and then hold the "boost" button. This should get you into a menu. Use the up and down pad to scroll through the options until you find "clock" hold the center button to get into the mode, to set the clock. Once in use the up and down, left and right pad to set the time. Then press the menu button to get out. Press the source button to get back into a normal mode, then hold that "boost" button again. This should bring you into a different menu. scroll through the menu until you see "display" and you should be able to choose to display clock in there. I hope I didn't steer you wrong. Let me know if you need further help. Good luck
-Andrew Hawkins
14helpful
2answers
Time
To set the clock, you need to be in standby mode. Push and hold the B. Boost/menu button. Menu will show up. Use the RT knob up and down until you find "CLCK". Then push the RT knob down until the clock and ADJU shows up. Use the RT control to adjust the time. In normal mode to show and hide the clock, hold down the RT knob.
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
