KLX 125 sat for 2 years, carb removed, cleaned, cleaned, cleaned, re-installed no air filter restriction, runs great at 600- approx 2500 rpm then 2/3 throttle to full throttle, bogs. all passages appear clean on main jet, float level good, good compression, ran fine before storage according to previous owner
Be certain the battery is in good condition. Install a new spark plug. Clean the carb and air filter. Use the throttle sparingly. The carb has a power valve that gives an extra shot of gas each time the throttle is twisted. Too many twists and the engine floods out. Please rate my answer. Thanks!
Down is choke "ON" and up is choke "OFF". Had same question and found on another site. Made carb adjusrment much easier after cleaning. Bike was new to me and runs great now.
i'd say the carb is gummed up especially the pilot jet (#16158) in this pic of the USA carb. may have to remove the carb & bowl and then remove the pilot jet (w/ flat head screw driver) and clean out the tiny holes.
the carb slide is installed backwards (turned 180 degrees). its #16025 in the pic. i've done this before on my daughter's XR70 and Z50. you'll know if its this when you move the choke lever, RPMs increase and decrease.
I have had several bikes in my time. and keeping the carbs syncranized is very important. Did you put aftermarket pipes on it? try rejeting the carbs up 2+mm that may help the fuel air ratio?
on a 4 stroke engine?
