Question about Kodak Office Equipment & Supplies
U9 error code on 4600 scanner, but it is not a paper jam.
5 Related Answers
mohanchennai
Mohan Sriraman
  • 490 Answers
SOURCE: iDoc scanner Canon DR-9080C has a P00 error when not paper jam found?
There are sensors in the paper path. Just blow air to ensure that there is no shreds of paper is blocking the sensor.
S. Mohan, Chennai
Posted on Jun 30, 2008
TechSatya
Scan Aid
  • 104 Answers
SOURCE: Avision AV830c plus scnaner paper jam error
Hi, Can you provide the detailed description of the issue? Is there any on screen error message or panel error code? regards, TechSatya
Posted on Jul 14, 2008
marcus trashbox
  • 8 Answers
SOURCE: Fujitsu FI 5120C pop up error for paper jam
Please clean the separation pad and the pick roller.
If this don't help change them.
The Fujitsu sparepart numbers:
pad PA03289-0003
pick roller PA03289-0001
Posted on Jul 15, 2008
Anonymous
  • 6 Answers
SOURCE: paper jam error, but no jam present
mabey its the wrong paper youre putting in it:O?
Posted on Jan 03, 2009
Anonymous
SOURCE: Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Posted on Jan 31, 2009
What causes the error code J?
The error code J in Fujitsu fi-6140 scanner is associated with Document jam or feeding related issues. J-0 error is paper jam error caused by paper protection sensor malfunction, J-1 is also paper jam caused by US sensor malfunction and J-2 multifeed error caused by poor performance or malfunction of US sensor error.
Regards,
ScanCare
Aug 13, 2014 | Fujitsu Fi-6140 High Performance Color...
Kodak U9 error code. How do you clear it?
we are facing problem Kodak i4600 scanner error u9 .we replaced udds Sensor same problem.
Aug 22, 2013 | Kodak Office Equipment & Supplies
I cannot print or copy . i see error 51
Error 51 is a paper jam code. Remove the paper tray in the front and the jam clear cover in the back (the light gray plastic piece in the center of the rear of the printer) and pull out any paper you can see.
Once you've removed the paper, the jam code should clear on the display, but if it doesn't, try resetting the machine. If the jam code is still there, that means there is still paper somewhere inside the machine. Check again to make sure you didn't miss any, and also lift the scanner bed to see if you can see any paper under there. (To lift the scanner, lift up with the tabs on either side until the scanner locks into place.)
Jun 03, 2010 | Brother Multi-Function Center MFC-240C...
Fi-6130 not grabbing paper, displays Code: DS32002
My scanner is Fujitsu M4097D. I just have problem with ADF: Error Code DS32002: Paper jam in the ADF. Here is my solution: 1. Bend two white platin pieces down a little bit in order to "sensor" the paper scanned. This problem is occurred after I am scanning 50 thick pages. Until paper count 42, it is stopped with error code DS32002. Hope help anybody having this problem.
Jan 06, 2010 | Fujitsu ScanPartner fi-5120C Pass-Through...
Cannon pixma ip 4600 error code 5700 - paper jam
The error code 5700 is the sensor error.Replace the sheet
feed unit and then adjust the timing of the paper feed gears.
Sep 02, 2009 | Canon PIXMA iP4600 Color InkJet Photo...
ADF paper jam, when there is none
If you are receiving an Error Code 103 or a Paper Jam error, but there are no pages in the ADF (Automatic Document Feeder), follow the steps below:
  1. Close the scanning application (such as PaperPort)
  2. Turn off the scanner and the computer
  3. If you have a combination ADF with a Flatbed scanner, unplug the ADF cable from the base of the scanner
  4. Plug the ADF cable back in
  5. Turn on the scanner power
  6. Turn on the computer
  7. Try scanning again
For a Paper Jam or Error Code 103, make sure that the ADF cable in the rear is connected to the scanner base. Check the flatbed to make sure that it is clear. A page incorrectly placed on the flatbed may interfere with a page feeding through the ADF.
If your scanner stops scanning due to a paper jam in the Automatic Document Feeder (ADF), a warning dialog box appears after a few moments.
To clear a paper jam:
  1. Open the Automatic Document Feeder cover.
  2. Remove the jammed paper and close the cover.
If you are receiving a paper jam error, or if the scanner is running continuously, check to make sure the paper sensor arm is not stuck down.
  2. Look for the small black plastic arm
  3. When you press on this arm, it should move freely up and down
  4. If the arm is stuck down, please contact Technical Support for troubleshooting options
  5. Close the ADF cover.
May 26, 2009 | HP Scanjet 8350 Flatbed Scanner
Xerox 5328 copier error
U9-3
Xerographic process problem.
The Exposure sensor detected low Exposure Lamp intensity. Switch the Main Power Switch off then on in order to clear the Status Code. Go to the U9-3 Xerographic Process Problem RAP
U9-4
The Main PWB sensed that the Toner Dispense Motor was not running. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP
U9-5
The CSDC zero point was too high during auto setup. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP U9-5 Xerographic Process Problem RAP .
Aug 09, 2008 | Office Equipment & Supplies
Mar 08, 2008 | Avision AV 3200 C Flatbed Scanner
MFC 4600
Some paper has torn or a part is broken, have a very good look for any loose bits of paper. Take the ink out if you need to. 90% chance you'll find a small bit of paper that's causing the rollers to resist and the printer to stop with the error.
Nov 09, 2007 | Brother MFC 4600 Laser Printer
Open Questions:
553 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
