Question about Visonik Car Audio & Video
Where do I buy screws for a 600 watt Visonik amp? I have two and i need all 7 to install the amp. Regular machine screws do not fit.
Posted by Ben Snyder on
5 Related Answers
Anonymous
  • 5 Answers
SOURCE: 600 watt 2 channel power acoustik sterling amp
On your amp, there should be a switch (on the side probably) that has "LP", "HP", and "FULL" or "OFF". This is a switch for the low pass/high pass filter. Switch it to "LP" as this will allow only low frequencies to go to your subs, what you want. If you don't have that switch, go to an audio store or online audio supplier and get either a low pass filter, band pass filter, or a cross-over, and follow the wiring diagram that comes with it to filter out the high frequencies before they get to your subs.
Posted on Oct 09, 2007
Anonymous
  • 883 Answers
SOURCE: what size fuse do i need for amp
start with a 50, may need to increase it if you are not using a large capacitor.
600 watts = 12x
x= 600 watts / 12 volts
x = 50 amps
Posted on Dec 13, 2007
Pierre Laplante
  • 2042 Answers
SOURCE: my battery dead when i want to turn on car--what do i need?????
monster cable its good for our amp but do nothing for the battery its all depend how many amp our amp take away from the battery if our alternator is 90 amp maximum the alternator output is 75% off 90 amp =70 amp available if each amp take 25 amp you only have 20 amp left for everything else there no way our alternator is enough that y you drain the battery you need a bigger alternator and battery the minimum you can do is put ourself another battery you gonna have more capacite but you gonna have to charge it up at night put a little battery charger 2 or 3 amp per hour that should fix it cheaply hope it help dont forget to rate me cheers
Posted on Jan 18, 2008
Anonymous
  • 655 Answers
SOURCE: DONT KNOW HOW TO RUN 2 OHMS
Hello storres18,
If you have the Kicker model number 06CVX122, with dual 2ohm voice coils, they can be connected to a mono amp at 2ohms. First jumper the voice coils in series, the dotted positive (+) to the undotted negative (-) (or vice versa). Each sub is now 4ohms. Then wire both of the remaining positives and negatives together on the amp terminals (in parallel). The amp sees a 2ohm load. Here's the diagram:
If you have the Kicker model number 06CVX124 with dual 4ohm voice coils, they cannot be wired to present a 2ohm load. They can only be wired as a 1ohm load (too low for the amp) or as a 4ohm load (at reduced power). Here is the diagram of the 4ohm wiring:
Hope this helps.
Posted on May 10, 2009
michael whitman
  • 102 Answers
SOURCE: how many watts are in the kicker comp zr600 amp? i
  • Amplifier Type: Dual Channel
  • Bridgable: Bridgable
  • RMS Power at 4 Ohms: 150 W x 2
  • RMS Power at 2 Ohms: 300 W x 2
heres a link to a stats page for the zr600>
http://www4.shopping.com/xPO-Kicker-ZR600#keyFeaturesArea
Posted on Feb 05, 2010
What type of amp do I need for apair of rfdj1 12" dj 600w band speakers?
The 600 watt rating is FAKE like most of our advertising and will be either 600 watts PEAK or 600 watts PROGRAM. If it is Peak, use an amplifier with no more than 100 watts a side RMS... If it is program rating use an amp with no more than 150 watts a side RMS but that is pushing it for speaker safety. Also pay attention to the spec of the amp as to what it will output at the impedance of the speakers. I read the spec on the speakers... they are rated 150 watts RMS, NOT 600 watts... Use an amp rated at 150 watts RMS MAXIMUM at 4 ohms per side. Also don't turn up the bass excessively or you be buying new speakers. Twelve inch speakers would be adequate for a 20 by 20 room at SAFE listening levels. If you want driving bass, you need to get an 18 inch subwoofer.
Jul 14, 2011 | Rockford Fosgate Rfdj1 12" 2-way Passive...
Wired up dimmer light output is not the same as when i hook it up to a regular switch
1) Overview of product indicates it dims by electronics (they say saves 15% electricity)
The electronics might be bad
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/MaestroDimmerSwitch/Pages/Overview.aspx
2) Load types
Different dimmers are made to work with different types of lighting
Depending on your model number, the type of load may be a factor
http://www.lutron.com/Products/StandAloneControls/Dimmers-Switches/MaestroDimmerSwitch/Pages/Models.aspx
3) Total load
A regular 15 amp light switch carries 1440 watts
If you have the 600 Watt dimmer, load wattage should not exceed 600W >>> add up total bulb wattage
4) Lutron seems to have about 60 different manuals
A quick look at the wiring seems straightforward 1-1 wiring replacement with ordinary switch
Did you connect ground wire to green screw on dimmer?
5) If the dimmer and load requirements match with the dimmer you own, I think the problem might be a short .... exactly where the short is located is solvable by testing the lights and timer and surrounding circuits with a multi-tester >>> the testing would start at the dimmer.
6) All considered, you could replace the dimmer with another one from Home Depot and see if same problem persists.
Oct 16, 2010 | Maestro Lutron Dimmer 600 Watts Ma-600-wh
Sub box
it all depend on were you are putting these subs at. the dimesion on the trunk of a honda to a lincoln are vastly different
Jul 09, 2009 | Legacy (LA568) Car Audio Amplifier
Visonik V12D4
i would wire the coils of each sub in series which would yield an 8 ohm resistive load per sub - and then wire the subs in parallel to the amp which would bring the resistance back to 4 ohms for a bridged load which will give you max power handling from the subs and draw the full power of the amp at the same time
Jun 18, 2009 | Earthquake Sound PH800W.2 Car Audio...
What fuse do I use for a 600 watt car amplifier
956
You will need a 6 Gauge wiring kit with a 50amp fuse to the battery. You can verify this by looking at the kits being sold on the internet for 600 Watt car amps.
Apr 18, 2009 | Audio Players & Recorders
Thumping speakers - no power light is on - wired correctly
the amp is going into protect mode due to something wrong in the amp or some thing in the wiring to it ooh yea if you are getting 18v power to the amp that is way to high it should not be higher then 15v if the amp is in protect mode it will not play at all.
Nov 02, 2008 | Visonik Dual Bass Box with Amplifier Car...
Amp Power light will not go on. Protection light is lit- Thump sound in speakers
It probably has shorted output transistors. To eliminate other possible causes, read through the following page.
Amplifier in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Oct 31, 2008 | Visonik Dual Bass Box with Amplifier Car...
Installing visonik bass system
Here is a link to visonik to download manuals.
http://old.visonik.de/en/downloads.php
If you let me know your model number of the sub, vehicle make and model, and brand and model of headunit or CD player you have then i can provide wiring color codes, recommended wire routing locations, etc...
Jan 03, 2008 | Visonik 10" 500-Watt Single Bandpass...
Amp problems
It's fried. Repair costs are more than the amp is worth. Sorry, it's a lost cause.
Oct 19, 2006 | Visonik V117SX Car Audio Amplifier
Car Audio & Video Logo
Top Visonik Car Audio & Video Experts
xxxxxx xxx
Are you a Visonik Car Audio and Video Expert? Answer questions, earn points and help others
