Whirlpool RBD305PD Electric Double Oven Logo
Posted on Sep 08, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Whirlpool double oven rb130pxv
I took the bottom door off now I cant get it back in, older model about 1974
Dave Harrison
Level 2:
  • Expert 114 Answers
  • Posted on Sep 27, 2007
Dave Harrison
Expert
Level 2:
Answers
114
Questions
0
Helped
66064
Points
245
As long as you line up the hinges with the receptacle in the door, it should slide right down. Try a shot of WD-40 on both.
I have a whirlpool accubake wall unit oven Took out door to clean glass now I cannot put door back together
you have a couple of hinges you have to pull out at about 45 degrees then slide door down on them and shut door
How do I get the door I removed back on my 1964 Whirlpool double oven?
THERE ARE USUALY 2 LEVERS OR HOOKS ON THE BOTTOM OF THE DOOR THAT YOU NEED TO LINE UP WITH THE HOLES THAT ARE ON THE OVEN. YOU NEED TO LINE THEM UP AT AN ANGLE & NEEDS TO BE STRAIGHT TO SLIDE IN.
Double oven no model number Whirlpool 14 years old Door is locked after self clean and display is blank
Your oven has resetable high limit thermostat that tripped off on the self clean cycle,im not sure if you have free standing,or a wall oven if freestanding the t-stat is on back panel if wall oven its behind control panel on upper oven and for lower oven its behind the grill between bottom of upper oven and top of lower oven. In either case it has a small red button that can be pushed in to reset it
Hope this helps and if it does please give me 4 thumbs up
Gene
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
1helpful
Took the oven door off and now cant get it back on
Typically one cannot fight the hinges while putting the door on.
USUALLY you can move a hinge down/open and there is a hole to put a nail through to hold each hinge down while you get the door in place.
My whirlpool double oven lower door won't stay closed all the way. model RBD305PD810. is there an adjustment that is needed?
If it is a drop down door, then you need to replace both door hinges, if it is a door that opens sideways, then it is probably the door catch, or door striker that needs to be replaced.
Please rate my solution.
Thanks.
My oven door will not shut tightly
Hi, I take it that this a whirlpool oven? Single or double oven? If it is a double your in luck! Your door hinges need replacing along with the inserts that are located inside the oven cavity. You can exchange the hinges and inserts from the oven doors and hinges if you have a double oven. If not get some new ones and fit them in! Easy job you will just need a little guidence as some models do differ..
Get back to me if this is usefull.....
Whirlpool oven door
The metal bars go under the top door handle part, put them under the part you need to screw back in.
Cannot re-fit middle glasss into main oven door
this is a new one too me but ill give a shot
ive never seen an over where the supports were all intack
they should be screwed in at least to of them by what i call the hidden screw or plug either the 2 bottom come out or the 2 top ones come out to where the glass slides into position and just put the supports back into place
i was reading reviews on this particular item and clearly by what there describing this is not a very good functioning machine all out of tune from the older style
Maytag "Magic Chef" electric double wall oven
check the high limit swtich. You need to remove the back of unit to find it. replaced it part# is:w10175596
Top Whirlpool Ovens Experts
ZJ Limited
ZJ Limited
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
