Question about Sharp EL-520WBBK Calculator
How to calculate
How to do a logarithm calculation on a calculator Sharp el 520w
Posted by cindy_gebara on
  • Anonymous Mar 18, 2014
    how to remove DEG on sharp EL-520w
    how do i remove DEG, on sharp EL -520w calculator, does this gives error while doing stats?
Anonymous
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 81 Answers
It's very simple: the calculators have a default base 10 so that log x it's log x base 10 so here is some logs:
log x base y = log x / log y
log (x*y) = log x + log y
log (x/y) = log x - log y
Hope it's helped
Posted on Jul 06, 2009
How to darken sharp el-520w contrast?
If it can be done, you need to press SETUP then choose CTRST and use your left and right arrow keys to adjust the darkness of the digits on the screen. Unfortunately, some of the older models do not have this ability so if you do not find that that menu option it means that you cannot do it on the calculator.
Jun 25, 2014 | Sharp EL-520WBBK Dual-Powered 12 Digit...
How do you do logorithms on the sharp advanced DAL EL-531x?
For decimal logarithms, use the key log.
For natural logarithms, use the LN key
Jun 11, 2014 | Texas Instruments TI-30 XIIb Calculator
Log2(0.25)=-2
You can compute the logarithm of x to any base by computing log(x)/log(b) or ln(x)/ln(b). So, press
ln . 2 5 / ln 2 = or
log . 2 5 / log 2 =
Oct 01, 2013 | Sharp EL-531VB Calculator
EL 531X Sharp - Help with calculations
You need a SHARP with Write-View display capabilities. The EL-531X is unable to show that. The Write-View calculators from Shard have a W, example EL-W516 followed by Write-View. Not to be confused with the W in EL-520W
Feb 21, 2013 | Sharp el-531x scientific calculator
How do you calculate expected value on the sharp el 520w
Set up the correct formula on paper and follow it. Use parentheses to avoid ambiguities.
May 18, 2012 | Sharp EL-520WBBK Calculator
How do I get my SHARP EL-520W ADVANCED D.A.L. to display my answer in radical form?
Unfortunately, you don't. The EL-520W can show fractions, but not radicals.
Apr 05, 2012 | Sharp Office Equipment & Supplies
Cant find the Log function on the EL 733A
There is no common logarithm function on this calculator. However, you can calculate it easily enough using the natural logarithm function (ln). The log of x is equal to ln(x) / ln(10). In words, calculate the log of a number by calculating its ln then dividing by ln of ten.
Mar 02, 2011 | Sharp EL-733A Calculator
How to calculate logarithms using SHARP EL-531WH
you can press the "log" button or the "ln" for logarithmic calculations. the difference is just that "ln" calculates log on base "e".
Feb 18, 2011 | Sharp EL-531VB Calculator
How do i get rid of the "p" on my sharp caculator. I have a EL-520W
On the back of the calculator, there is a little "reset" hole. Use a pen and press it into that hole for a few seconds, then release. You should now be able to turn on your calculator as if it was brand new from factory without the "p".
May 19, 2010 | Sharp EL-520WBBK Calculator
Sharp EL-520WBBK Calculator Logo
812 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
