Question about Braun Silk-epil 3370 Epilator
Main rotator is not working although the motor is fine i dont kno
I dont know how to open the body so that i can put back the rotator back in place
Posted by marinamusawa on
Anonymous
  • 276 Answers
I have access to Use Instructions if you wish, I can put them on our website if you want.
Posted on Apr 10, 2009
The brush won't move to scrub the carpet..it did before.now it doesn't
Almost all brushes are driven by a rubber belt from the spindle of a small motor mounted in the head. Some are driven directly buy the machines main motor. Most likely the belt has come off its track or was split or broken. If disassembling the cover or case where the belt resides is over your ability (check the original owners manual or website for your model) , find a youtube video by quering on your machines model to see hows its done. New belts are common locally. Dont force screws when reassembling As you might break the plastic that holds them. See tip below.
TIP: When putting screws back in plastic holes, place the screw in the hole, apply very slight pressure, and slowly rotate it backwards until you feel or hear a slight click then rotate the screw into place normally. This insures you found the original threads and will help prevent 'stripping' the hole of the material holding the screw.
Sep 21, 2015 • Vacuums
I have a lexmoto xtrs 125 2012 the starter spins fine now Ive cleaned it up. I benched tested spins fast and free. And I took the plate of the engine opposite starter motor. Chogs all good . Seems like...
put the starter motor back together wrong
dc motors are polarity sensitive so reversing the main power wire will reverse the rotation of the armature
Jun 16, 2017 • Motorcycles
Maytag Dryer- Drum not rotating (belt and motor both work)
I surely do hope this fixes it all.
The pulley that fell apart is supposed to. Well, not quite. It is not fastened inside the machine, and comes off easily. It is the belt tensioner. It fits into 2 slots on the bottom steel panel of the machine (The base)
You will be finding it is a pain in the neck to put back on, but you can do so. The belt goes with the grooves toward the drum, not away from it. The belt goes in a S shape around the motor pulley and the tensioner pulley. One you put the tensioner back in it's place nin the two slots, you will push (or pull) on it against the spring arm to "bend" it so as to get the belt back on.
Be blessed.
Intermittent ignition problem
Could if knew what year , make , model an engine size ?
Is it hard to put a straight axle under the front of a 05 chevy 1500 reg cab 4x4 the IFS on this thang sucks and its costing me lots of money cv axles and tires
You will have to use heavy steel square tubbing across front frame for spring hangers and on the back the spring hangers will be threw the frame,,welding torch , cutting torch and a place to do it,,if it's your everyday driver I suggest not doing it
1helpful
2answers
Hi, I have a JVC AL-E11BK fully automatic turntable. I need to replace the belt. Could you please advice me on how to do it? I cannot lift the platter because of the centre clip. I don't know what to do...
remove rubber pladder and use a flat blade screwdriver to remove the clip "carefull it may take off on you" next slide off the pladder, remove the old belt. Now! take the new belt put it around the inner part of the pladder, next put the pladder partly back on the center spindle and rotate until one hole lines up with the motor, take a hook and slip it under belt now carefully stretch over to the motor put on and push pladder into place and rotate it by hand clockwise to make sure it is in place, next reseat rubber pladder back on and power up to make sure it is working before replace the clip.
3helpful
2answers
My philips dvdr3510v player is not opening tray its saying blocked how do i solve the problem
This seems to be a manufacturing problem. When the disk is loaded it is centered on a spindle and to make sure that centering succeeds a magnet mounted to a small white rotating plastic piece on the top of the DVD drive. The magnet seems to bee too strong on my machine so the spindle isn't able to disengage when trying to open the tray. The result is blocking. It is of course possible that the electric motor moving the tray and the spindle movement is too weak. Anyhow this is how I solved the problem on my Philips Video/DVS DVDR3510V:
1) Disconnect the device from mains power.
2) Unscrew the eight screws holding the top in place.
3) Unscew four black screws keeping the DVD unit fixed to the main body.
4) Carefully drag the DVD slightly back which allows you to rotate it to point sideways (this allows simpler testing of the mechanical working).
5) Unscew the two blank screws keeping the front half of the top of the DVD unit in place.
6) Using a small screw driver carefully bend the clips to allow the top plate to be removed.
7) Connect the mains power and don't ouch anything inside.
8) After startup try Eject/Load several times to ensure that the DVD unit is mechanically working OK. If the Eject/Load doesnt work with the top off there is no use going further.
9) Disconnect mains power.
10) Use a small felt tipped pen to mark the face of the small metallic (magnet) part in the center of the white movable component fixed to the top.
11) Using a small flat screw driver carefully open the clips holding the two halves of the white component together. Careful! The clips may break easily.
12) Cut small pieces of tape (or use thick drawing paper). The idea is to lift the magnet slightly upwards. We thus use tape or paper as shims. Notice that a hole is needed in the center.
13) When the shims are in place put the magnet back oriented correctly (if you didn't mark it test it against the spindle rotating the disk. The correct orientation is where the magnetic force is strong.
14) Mount the halves back into the hole in the top component and align the clips. Then press the halves together until the clips connect.
15) Put the top component back and clip it into place. No need to screw in the screws yet.
16) Connect mains power, don't touch anything inside.
17) Check that the tray now opens both with a disk and when empty. Check that a DVD is recognized correctly (too little pressure leads to disk loading failure).
18) If the DVD unit now works assemble it and you are done.
The first picture shows the white round plastic part that is modified on the left hand side of picture.
The second picture shows an additional support I glued to the top with super glue because the top is fairly flexible. Initially I thought this was the reason why the spindle got stuck. I think the extra support is unnecessary but i didn't bother with removing it.
Dec 29, 2010 • Cameras
3answers
I have a 98 chevy blazer that will not start unless we s pray starting fluid in it we have replaced the fuel pump, injectors, distributor, and throtle body. All the pressures are fine. What else could it...
before u change anything else,,,,put a scanner on it ,,snap on,, mac ,,metco,,& while cranking it reed the variables in each , to even see if their work in ,,or get a spark tester,,their cheep,,plug it in,,turn motor over,,if no spark,,could be pickup coil,,cam,,or crank censer,,hoped it helped
4helpful
Belt amana washer replace mod lw6501w2
I have a similar amana top load washer and just changed the belt. Here are the steps I used to change the belt:
1) Unplug the washer
2) Slide the washer away from the wall about 12"
3) Remove two screws from the bottom of the front panel, slide the front panel down (there are 2 metal tabs that slide into slots on the top of the front panel - observe how they slide into/out of the slots). Set the panel aside.
4) Remove the electrical connector (upper left of motor). Press down on the top of the plastic connector - this will undo the catch hook holding the connection in place). Observe how the belt is routed before proceeding.
5) Remove 4 bolts holding the motor in place. You can remove the motor - even with the water pump and hoses in place - they will flex.
6) Remove the water pump from the motor. There are 3 torx - head screws to remove. Note: You will need a star shaped (torx) head driver (Looks like a screwdriver but with a "star" head on it. The one I used measured just under 3/16 in diameter.
7) carefully remove the water pump. - remove the old belt from main pulley under washer drum and also from the water pump. Insert the new belt - be sure to put the tension pulley on the outside of the belt.
8) Reinstall the water pump to the motor. Reinstall the motor. Route the belt correctly in the water pump body area first - them slide the belt around the left side of the main drum pulley - rotate the pulley counter-clockwise and the pulley will tug the belt onto the pulley. Once in place - check bolts and belt - then reattach the electrical connector (remember to press the plastic lever on top of the plastic connector before sliding it in place). Reattach front panel - slide the top of the panel onto the metal tabs - then attach screws at the bottom.
Braun Silk-epil 3370 Epilator Logo
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
reference30
Michael Thomas
Michael Thomas
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
