Question about Kenwood HD20GA7 MP3 Player
SYSTEM ERROR 0000020 - Kenwood HD20GA7 MP3 Player
1helpful
How to affix the error 0000020-0281-05
drum patch sensor polluted for more assist call tech support
My 7410 All-in-One printer stopped in a blue screen with 00000020
0000020 is a BIOS error code for WiFi communication error. (Took me HOURS to find that in 2008!)
1. Power down the printer - disconnect the power supply 20 seconds. Restart it while pressing the ON along with OK both for 3-5 seconds. This will recover a failed BIOS. However, if the WiFi really is dead (and it IS the weakest link in the printer), you may get the error again.
2. Power off the printer (again). Disconnect the WiFi card (back panel, look for a 6-7 wire cable wrapped in plastic tape). If the printer restarts, you have your answer... but not the solution!
3. HP7400-series WiFi cards are rare as hens-teeth these days. Mine failed a 2d time; I use the cat5e connector and just leave the WiFi disconnected.
8helpful
5answers
3answers
Mi copiadora IR 5020 se para y arroja cod E 0000020 y manda a apagar y encender el equipo que es este error
check the toner hopper maybe the toner is empty or the hopper motor is failed to fuction
System error problem
when i turn the gigabeat on it say system error what happen to it?
System error on toshiba 40gb mp3 player
Try reformating the player using gigabeat format program see pg.52 owner's manual than restore the firmware data in the player see pg.51
Please help
Toshiba Gigabeat support is 1-877-250-8595
Owners manual
Hi! Dear I have Owners Manual I can email you Also can you explain me how to open Gigabeat to remove battery and HD Please email me at [email protected] I will attached manual once you provide me your email Thanks Jitu
3answers
System error 0000020
1.U need to reformat player first: see page 52 of owners manual(application software) 2.when formatting with gigabeat finished u need to restore of the firmware data see page 51 of the manual. Piece of cake,dude!
Gigabeat System Error Problem
Error message 0000020 - System Error displayed whenevr devide powered up. Only way to shut down is by turning battery off. Gigabeat Software on PC not able to detect device, not listed in Device Manager or as an external drive in My Computer. (As it normally is) Is there a way to reinstall firmware from PC when device not detected?
Kenwood HD20GA7 MP3 Player Logo
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Morne Olivier
 Francisco Mauricio...
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
