My JVC DVD burner (CU-VD10) is refusing to recognise DVD inserted and keeps up coming up with the message incompartible disc. I have tried using numerous JVC and Sony DVD-R and DVR-RW discs to no avail.
The burner is connected to a JVC Enverio GZ505 camcorder.
see if the player tries to read the disc. Load a disc and listen.
Does
the player make squealing noises or is it totally quiet? Squealing
noises may indicate that the player is trying to synchronize with the
disc but can't due to an obstruction on the lens or in the laser path
inside the pickup or a defect in the pickup. This can also be caused by
an intermittent signal problem due to a faulty ribbon cable.
Totally
silent means that the photo sensor is not getting any usable input from
the laser at all, meaning that the pickup is "blind" for lack of a
better word.
This can be caused by an obstruction of the beam by
foreign matter on the lens or inside the pickup all the way to a
marginal or failed laser diode and/or photosensor array. This can also
be caused by a bad ribbon cable with one or more severed traces.
You
could try to clean the optics. This is the most common malfunction as
far as i know in all disc players. It would involve taking the cover
off and finding a way to expose the lense, and then cleaning it with a
very gentle brush. some players have a cover for the lense that swings
to the side during playing, this greatly reduces the chance of dust
accumulating, but its still worth the try.
If you actually see dust on the lense, then its just that simple. clean, close, play.
It may also be worth your while to check on the small shafting that
guides the carriage of the laser pickup. Dirt, grome, dust and
solidified lubricant can cause stoppage of the carriage and the laser
eye then fails to read the next track. Please refer to the image i have attached.
Also Make
sure your box is not blowing really hot air and nothing is right behind
it blocking it.. Turn it off for a
few minutes and let it cool down and then give it a try playing the discs..
I have the same problem. I took mine back to BestBuy where it was bought from and they said these burners fail and wanted to sell me another new one for $200!
I have the same problem. The disc is unrecognizable. I have a JVC DVD burner CU-VD10. I connect it to a JVC Everio GZ-MG27U.
