The code i have is: 21436 14398 6975 9008
As you said you received the projector from your fried.and if its new i dint know.but if he was using it he must have definately set a password in it.but now at present you dont remember the password dont worry there is a system to reset the password and i m providing that as follows:--
If you forget the password
You will be asked to enter the four digit password every time you turn on the projector. If
you enter the wrong password, the password error message displays. You can retry by
turning off the projector (by pressing Power) and start again, or if you did not record the
password in this manual, and you absolutely do not remember it, you can use the password
recall procedure.
To enter the password recall procedure
Press and hold Right4 for 5 seconds. The projector will display a coded number on the
screen. Seek help from the local BenQ service center to decode the number. You may be
required to provide proof of purchase documentation to verify that you are an authorized
user of the projector.
To change the password
1. Open the on-screen menu and go to Setting > Change Password.
2. Press Left 3 or Right4. A “Password Change” message displays.
3. Enter the old password.
i. If the password is correct, you can go on to enter new password.
IMPORTANT: Write your selected password down here in this manual so that it is available to
you should you ever forget it.
Password: __ __ __ __
Keep this manual in a safe place.
ii. If the password is incorrect, a “Password Error” message displays. Press Up 5 to
try again or press Down 6 to cancel.
4. Check the new password.
i. Pressing Auto completes the procedure.
ii. Press Up 5 to try again.
iii. Press Down 6 to cancel the set-up and return to the on-screen menu.
THIS IS THE DIRECT LINK FOR YOUR PROJECTOR CLICK IT DIRECTLY AND GO TO PAGE NUMBER
27 TO PAGE NUMBER 29.every thing is mentioned in detail there
http://www.ece.osu.edu/computing/MP620p-en.pdf
please do rate the solutionand keep updated.thank you for using fixya.
I would try 2413, 2143, 4321. I have a call in to a friend that works at benq he should get back to me soon.
Standby, i'll sent you how for a while
Friend try this solutions;
1.you may try all "0000" first and then let me know if that worked
2.You need to write down the 4 groups of 4 or 5 digits the projector is showing up and, with that number and a proof of purchase, your local BenQ support office might give you the 4 digits code.
just try it first i'll give you more
General Product Info
Weight:
6 lbs.
Also known as:
BenQ MP620C, BenQ MP620c, BenQ
Manufacturer Part No.:
MP620C
Dimension:
10.9 in. x 3.7 in. x 8.7 in.(HxWxD)
UPCode:
840046095444
Try factory restore settings
U need to re install the the setup of ur projector through net ..
jus connect to net and run sofware updater , it will refresh ur password ..
If you forget the password: You will be asked to enter the four digit password every time you turn on the projector. If you enter the wrong password, the password error message displays. You can retry by pressing Up 5, pressing Power to turn off the projector and start again, or if you did not record the password in this manual, and you absolutely do not remember it, you can use the password recall procedure.
To enter the password recall procedure: Press and hold Right4 for 5 seconds. The projector will display a coded number on the screen. Seek help from the local BenQ service center to decode the number. You may be required to provide proof of purchase documentation to verify that you are an authorized user of the projector.
To change the password: 1. Open the on-screen menu and go to Setting > Change Password. 2. Press Left 3 or Right4. A “Password Change” message displays. 3. Enter the old password. i. If the password is correct, you can go on to enter new password.
ii. If the password is incorrect, a “Password Error” message displays. Press Up 5 to try again or press Down 6 to cancel. 4. Check the new password. i. Pressing Auto completes the procedure. ii. Press Up 5 to try again. iii. Press Down 6 to cancel the set-up and return to the on-screen menu
above procude will help you out
thanks and plse do not forget to accept the solution.
Hi!
You can see the procedure on the following link---
How to reset password
Please do accept the solution and revert back for any clarifications.
Thanks
Rylee
What happen?? why it command you a code? do you set the security? or there is a service problem on it/
You have to contact BENQ with the required code numbers to get an
unlock code. No one else can issue an unlock code. If the projector was
stolen, you will not get a code but will probably get a cop at your
door instead.
Contact BENQ in your local country by going to their web pages.
I hope this will solve your issue.
Good Luck.
If my solution proves useful please accept it.
Regards
Arjun
Which projector are you using? Have you talked to support guys of the company?
Regards,
Abhay.
Hi you can try to re-install the the setup of ur projector through internet
just connect to the internet via the usb cable and run software updater, it will restore your password to its default settings.
A master code was 9001.
If that does not work, then you have two ways out.
1 Contact Benq and have the password unloacked with a master code. Here is the contact page: http://benq.com/support/
2 Disassemble the projector completely (at your risk). Access to the
CMOS battery located on lower side of projector mainboard. Remove
battery for one minute to reset password.
Hi stiskau,
Try 0000
If that would not work, follow the below procedure to refresh the password....
u need to re install the the setup of ur projector through net ..
Thanks for using fixya.
Do rate this as "fixya"
Benq CP220 projector is in password mode. The coded password is 23183 15770 7533
check and reply me .....ok
The password i need only containes 4 digits.
i need a password with only 4 numbers
i can only use numbers from 1-4.
im using a Benq mp620c
I dont know why its asks me for a password, the projector was a gift from a friend that never had used it
The first time i turned it on, this screen with te password recuest came on.
i can only use the numbers 1,2,3,4 So 0000 aint possible.
The guy on benQ support couldnt help me.
If you can help me, you will make me a happy man:)
thank you
myjosh007
found anything myjosh007?
thanks tor trying, but the none of the codes was rigth.
if you can help me fix this problem, ill offcource rate "fixya"
