Sony PlayStation 2 Slimline Console Logo
A
Anonymous Posted on Aug 21, 2013
My ps2 model SCPH-90004 is not turning on when i turn my main switch on,sometime it gives red light but when i prees power button it suddenly turns green and turn,s off plzzz help me.
5 Related Answers
Anonymous
  • 134 Answers
  • Posted on Nov 02, 2007
SOURCE: Ps2 slim will not power up
usually, there is a problem with a ribbon cable of power/reset switch. Try using a replacement ribbon of the same type.
Anonymous
  • 28 Answers
  • Posted on Jan 30, 2008
SOURCE: My Ps2 light turns green then turns red
check to make sure your power cable is securely in, and check for any damage in the cable
Anonymous
  • 344 Answers
  • Posted on Jul 03, 2008
SOURCE: ps3's green light turns on usually screen stay's black
Call Sony so they can fix it. This sounds like multiple problems. Good luck.
Anonymous
  • Posted on Oct 23, 2009
SOURCE: ps2 turns itself off.
Hi, I had same problem, I just changed the fuse underneath mainboard, 3.15 Amp 120V If it doesn't work change this for 4AMP fuse
thstudio
  • Posted on Dec 20, 2009
SOURCE: How can i make ps2 SCPH - 90004 to play backup
I found the solution.
2answers
MY PS2 SCPH 90004 DOES NOT POWER UP ?
I think this issue is common among PS2, fixing it might cost you more than actually picking up one that is used from eBay. if you do want to try fixing it yourself you can try looking at some homemade YouTube videos, however it's not guaranteed that your problem would be exactly the same as displayed in the videos.
2helpful
2answers
7helpful
2answers
I have ps2 model no.SCPH-90004 CB.... can i install hard drive into it???
Yes if your PS2 is hacked you can connect an external hard drive.
Ps2 power light stays red
hello eric i've repaired a few ps2 most of the time it's been down to the power switch if not the power switch then the ribbon cable attach to the switch
regards
shaun
6helpful
PS2 will not play DVDs
hEy i hAd the sAme pRob...............dOn wOrRy all u hAv to do is to turn on uR pS2 witthout puttin a DVD oR aNy diSc........on mEnu screen gOto [options] by pRessing 'triangle' button......... a new screen will appear select by pressing 'X' [DISC SPEED]....n sEt it to fAst.....then insert the DVD movie........tURn off PS2....press n hold the reset button till the blue light is turned on......release the button and press it again.............. it wOuld take a little tYm foR uR DVD movie to be loAded........be patient till the movie plays it self..............
2helpful
Can the ps2 scph 90004 region code breakable if so how
There is more than one model of PS2, and more than one PS2 DVD player module. For some models or modules, only a Messiah 2 or Magic 2 chip installation will make them region free.
However, many can be made region free, for free.
Try this Tip for the steps:
Playstation2 Region Free Fix
I hope that helps.
1helpful
This is a PS2 Slim model SCPH 79001. Reset button does not work. When I plug it in the red LED lights up but when I push the reset button nothing happens.
check the connection, if you have the ps2 plugged in and it wont turn on it would be best to return it or have someone look at it.
My US PS2 won't turn on.
Seems like its just worn out,
i found that PS2 broke after a while, there was a stage were 4 of my mates broke in and around each other
1helpful
2answers
PS2 Modded Trouble Reading DVDr's
Your DVD potentiometer pot on the back of the PS2 laser lens needs to be readjusted. Some people will try to tell you it's out of alignment but if that was the case it would not read CD's. Some people will try to tell you the laser lens is bad. If that was the case it would not read CD's. On the back of the laser lens are two potentiometer pots. In english? Two lil screws that are turnable. One controls the power of the DVD laser one controls the power of the CD laser.
http://www.cyber-mag.com/station/laserV9.htm
That link will give you pretty lil pictures of what i'm talking about :)
In a nut shell the story goes like this folks. If your PS2 won't read certain game DVD's that are of a certain color or if it all of a sudden mysteriously fails to read games it once read but will play cd's just fine, the voltage of the laser for DVD's is not set correctly. (this does needs manual tweeking from time to time if you take your ps2 and move it around alot or if you take it over to friends houses etc etc. Basicly alot of movment in general can take this out of alignment. Even keeping the PS2 on it's side could theoreticly (just my opinion) based on gravitational pull, unbalance the potentiometer.
RESOLUTION:
Step 1 identify your PS2 version:
Version 1 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U1"
Version 2 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U0"
Version 3 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U2"
Version 4 - SCPH-30000, 30001, 35001, 30002, 35002, 30003, 35003, 30004, or 35004, 8 screws on bottom of case
NOTE: Version 4 has 2 varieties of motherboard: Gap/No Gap, the difference between v4 "Gap" and v4 "No Gap" is the "Gap" is there's a spot in the center of bios chip where each side lacks solder points.
Version 5 - SCPH-30000R, 30001R, 30002R, 30003R, 30004R, or 30006R. Also, some SCPH-30000, 30001, 30002, 30003, and 30004 models have a V5/V6
NOTE: Version 5 & 6 - the difference between these two versions is one of the connectors in the corner.
Version 7 - SCPH-39000, 39001, 39002, 39003, 39004, 39008 or 37000
Version 8 - Only in Japanese consoles. SCPH-39000, or, SCPH-39006 (GH-022 BIOS 090)
Version 9 - if you have SCPH-50000, 50001, 50002, 50003, 50004, 50006, or 50007 you have a v9 or v10 board.
Version 10 - SCPH-5000x, with date code "3D" to the right and below the serial number on the back of the console. (GH-026 board)
NOTE: To know if its a v9/v10 start up PS2 with no game in it ,press triangle and check dvd driver version dvd ver 3.00 = v9 & dvd ver 3.02 = v10.
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find a small ''a'' under the SCPH number or have DATECODE "3C" you have a V9 PS2 main board. (GH-026 board).
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find DATE CODE "3D" as shown below, you have a V10 PS2 main board. (GH-026 board).
Version 12 - The new slimline PS2 consoles are referred to as PSTwo here, but elsewhere they are also known as "v12" units... their numbers are SCPH-70011/SCPH-70012, and also SCPH-70004 CB (Belgium).
Step 2 use either google or the link above. If you're using google your keyword search will be something like "ps2 v12 laser lens adjustment" *replace v12 with your ps2 model.
In either case navigate to the site and follow instructions to set the pots back to their factory default settings.
Top Sony Video Game Consoles & Games Experts
Grand Canyon Tech
Grand Canyon Tech
Jose Ramirez
ELECTRICKSUSA
ELECTRICKSUSA
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
