Question about Powerware 9120 UPS System
The UPS dont go to on batteri
We have problem with one of our ups onboard. We had dp trail and should go on ups power but one of our POWERWARE 9120 did not and our DP had a black out. I have not any manuals so the only trouble shooting I have done is to compare the settings from another one. Can you please help me?
Posted by ivan_electri on
alltra
    Scholar:
  • 39 Answers
The front display on the PW9120 should tell you the condition of the batteries. You can download a manual on the Powerware site for the UPS. Go through the UPS settings to ensure they match the factory settings. (By the way, the factory setting for the Input Voltage Frequency should be +/- 5%). Page throught the display to get what the current UPS readings are.
If the UPS won't hold a load when the input plug is pulled and the UPS factory settings are correct, you may need new batteries.
You do not have to remove the load to charge newly installed batteries. The Powerware 9120 has both a rectifier to supply the DC bus feeding the load on the inverter, and a charger to charge the batteries to full charge. After being on overnight, your UPS should be fully charged.
Posted on Feb 08, 2011
Anonymous
    Problem Solver:
  • 3 Answers
Replace the batteries with new one then power the UPS without load for three hours or more so that the batteries can be charged. Then disconnect or switch off power to the UPS and observe if it will till be on using the batteries. If it will be ON then your problem is solved but if it goes off then your UPS is on BYPASS
Posted on May 27, 2009
Ups dont power on
hi,
ups is the new?
if not will have to replace the battery
Jan 31, 2014 | Powerware 9120 UPS System
Hello, we have a Powerware 9120 and our question is: If you set the BYPASS option, can the batteries load?? Thank you
Not sure what you mean by load the batteries. Replace them? Yes. Bypass mode is typically used when servicing the unit. You can email Eaton if you like: [email protected]
Here is the legacy documentation page for the 9120 UPS:
Jun 30, 2011 | Powerware 9120 UPS System
I have a powerware 9120 (6kva) and about 1 week i replaced all 20 batteries after the UPS failed. but its displaying battery disconnected when i try to power it. i cant seem to figure the problem. i tried...
Did your UPS display "Battery disconnected" or did it display "Battery Failure"? If it was "Battery Failure", for some reason the Powerware 9120 will take almost 18 hours after plugging in to power after battery replacement to correct the Battery Failure indication. Charger has to charge up the batteries, followed by an automatic battery test by the UPS. If the indication was "Battery Disconnected", you will need to check the internal fuses to see if they are blown. If the UPS keeps blowing fuses, it will require a board repair.
Jun 12, 2011 | Powerware 9120 UPS System
WHAT IS THE PROCEDURE TO GHANGE THE BATTERIES OF BEST POWER 610 (6 KVA)
Hello Vasilis,
Please download the instrucions from the link provided below :
http://lit.powerware.com/ll_download.asp?file=m_best610_700vainstall_jun99.pdf
The document is in pdf format. You have to install the adobe acrobat reader.
Please download the adobe acrobat reader from the link provided below :
http://get.adobe.com/uk/reader/
May 06, 2011 | Powerware Best Power Best 610 3kVA UPS...
Hello, my Powerware 3105 beeps 3 times every 30 seconds or so. I think the battery is not working anymore because when I unplug the power source everything connected turns off. Can you confirm bad battery...
Your problem is showing up under the Powerware 9305 (a very large UPS) but your comments are about the 3105. It sounds like your battery is dead. If your UPS is over 3-5 years old, that's most likely the case. The website address to view the user manual is www.eaton.com/3105 You can contact Eaton directly, too. Eaton bought Powerware about 6 years ago. Here's the contact info. Be sure to have your serial and model numbers ready from the rating label on your UPS.
Toll Free: 1 800 356 5737
E-mail: [email protected]
Dec 16, 2010 | Powerware Series 9 9305 (PW930525KVA) UPS...
Need to locate someone to install batteries into our UPS Powerware 2000. Location, Tempe, AZ (Phoenix, AZ)
Try contacting Eaton. They bought Powerware about 6 years ago and the personnel are trained on older Powerware systems. If you have the part number and serial number from the rating label on the UPS, that would be helpful.
Nov 24, 2010 | Exide /Powerware PowerWare 2000 UPS...
When the machine is power on it show disconnect battery powerware 9120 2kva
There may be a broken batt lead or a failed cell or bloc inside.
try checking with software or
take out batts and test with meter.
if you dont understand how then get a tech to help. batts are dangerous.
Sep 13, 2009 | Powerware 9120 UPS System
Battery Failure
Hi
if the battery is bad you better to replace a new one!
Thanks!
Sep 23, 2008 | Powerware 9120 UPS System
Powerware 9120 UPS System Logo
233 people viewed this question
Top Powerware Computers & Internet Experts
Gruber Power...
Gruber Power...
Marvin
Marvin
Tom Chichester
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
