Nokia 6600 Logo
Question about Nokia 6600
Where do i have to insert the memory card in Nokia 6600?
I dont know where to insert the memory card in my Nokia 6600.
Posted by aisha_di_sco on
  • Anonymous May 11, 2010
    Hello aisha,
    could you tell us which Nokia 6600 do you mean !
    Old 6600 or Nokia Fold or Nokia 6600 Slide !
    ty
Anonymous
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
The SD memory card is inserted underneath the battery below the SIM card. The same lock the holds the SIM card also locks the memory card.
Good luck and thank you for using FixYa.
Posted on Apr 09, 2009
2 Related Answers
Anonymous
  • 452 Answers
SOURCE: NOKIA 6600 HAVING PROBLEM INSERT MEMERY CARD
there r two scenarios either ur using miniSD(used in 6681 & 6630) & it not properly fitted in this case u can use clutcher(it is easily available in the market) Or if it is 6600 MMC then go to memorycard option in the main menu of ur h.set & unlock the MMC. otherwise check if mMC is corrupted
Posted on Oct 10, 2007
Anonymous
  • 13 Answers
IF U HAVE THE CELLPHONE DRIVERS OF YOUR PHONE AND U GOT A COMPUTER AND THE CABLES FOR THE PHONE PLUG IT INTO YOUR COMPUTER IT WILL TELL U IT HAS DETECTED YOUR PHONE OPEN IT AND RIGHT CLICK ON THE DRIVE OF THE PHONE CARD MEMORY AND PRESS FORMAT YOUR CARD THAN SHOULD BE FINE AND ABLE TO WORK ON YOUR PHONE
GOOD LUCK
Posted on Feb 06, 2009
How to download mp3 format for nokia 6600 ? can you please guide me ?
Hello Anilijoseph,
Please remove the memory card from the phone.
Connect the memory card in computer or laptop.
Then transfer the mp3 songs in memory card.
Then insert the memory card in phone.
Mar 18, 2011 • Nokia 6600
1helpful
My 6600 does not read memory card and when i insert in another 6600 it reads it?
there may be some hardware problem
or you can use another card in your phone
you can also reset the phone settings to factory default.
if these trick dont work contact nokia care
Oct 11, 2009 • Nokia 6600
2answers
WHEN WE INSERT THE MEMORY CARD IN NOKIA 6600 AND OPEN IN MOBILE THE MESSAGE SHOW THAT ''MEMORY CARD CRUPPTED . PLZ GIVE ME THAT SOLUTION THANK YOU.
if you have a memory card reader (if you dont have get it from a friend)connect the memory card via the reader to the pc which has an original antivirus system. after the icon appears, right click on it and click on format. this will delete all the files in the memory card. i suppose you should have removed the card from the pc connection when a file is being transferred. after the memory card is formatted the cellphone wont show such message.
Jun 09, 2009 • Nokia 6600
1helpful
GOOD LUCK
Feb 06, 2009 • Nokia 6600
3helpful
Memory card has been corrupted
try to check it on other memory card slot
Nov 23, 2008 • Nokia 6600
22helpful
5answers
MMC memory card is corrupted (1GB). does not format.
Please try to format the memory card using a memory card reader on computer and then insert the card back in phone, it will say corrupted again, but now you try again to format it from phone and it should work now,,.....
Nov 06, 2008 • Nokia 6600
Repairs my corrupted Memory card
Try formatting memory card first formatting it with your computer with a card reader then insert it back into your Nokia 6600 and format again.
Had thesame problem once and it worked.
Let me know if it works for you, email me at [email protected].
Cheers.
May 24, 2008 • Nokia 6600
Top Nokia Cell Phones Experts
Muzahura Frank
Kolbrun...
Marvin
Marvin
