Question about Olympus DM-20 Digital Voice Recorder
I get an unexpected error message when I try to open Olympus Digital Management System Transcription Module Release 6
3 Related Answers
Anonymous
  • 928 Answers
SOURCE: Lost CD for Olympus AS-3000 Transcription kit, need to download
you can go to the link below and just follow the steps to get the right software.
http://www.olympus.co.uk/consumer/2590_software.cfm
Posted on Nov 16, 2008
Anonymous
  • 10 Answers
SOURCE: We are experiencing issues within the AS-5000
This is a know issue of the initial releases of DSS Pro 5. Downloading the update (using the Update option inside the software) will not really fix it, but will at least give you an option to override the Locked status. This "fix" appears from update 5.0.5
Posted on Jun 11, 2009
tscmusa
Mitch Davis
  • 95 Answers
SOURCE: looking for instruction manual for using Olympus
this should work:
http://www.olympusamerica.com/files/oima_cckb/AS-2400_Instructions_EN.pdf
Posted on Apr 05, 2010
Using a Transcription Module and getting this error message: "Dictation is not going into finished folder, also pending work coming up as finished."
Click start click to open on my computer you should see your drive could be C: or something right click select properties there will be an array of options
select the sharing tab option then advanced sharing make sure you have a tick in the share this folder box
then click permissions make sure you have all 3 boxes ticked full control changes and readin windows 7
If you are running a Windows XP OS then you might be able to:
Click start right click on my computer select open
Right click the icon of your Drive (It should be C:/ or something)
Click Properties in the menu that comes up
Click the Sharing tab
Click permissions
And finally, click Allow next to Full Control.
Jun 10, 2014 | Olympus DSS Player Transcription Module...
Olympus DSS Player Pro Woes!
Could it be that the files are just being regularly accessed by one of the server admin tools and the DSS Player application interprets an open file as 'being transcribed'
What happens when a copy of a .DSS file is made to an operators machine and then loaded locally for transcription?
Oct 21, 2007 | Olympus DS-40 Digital Voice Recorder
HOW TO INSTALL OLYMPUS DRIVER FOR FOOTSWITCH RS24
Hello your foot pedal don't need drivers but you need for sure a transcription software, the pedal will required a program to work together to control your audio files for example you can get a Olympus transcription software that will be compatible with your pedal, at http://www.tvps.com/Products/Olympus-AS-5002-DSS-Player-Pro-Version-5-Transcription-Software---New__OL-AS-5002.aspx or you also can used http://www.tvps.com/Products/Olympus-AS-7002-Pro-ODMS-R6-Transcription-Software---New__OL-AS-7002.aspx
May 01, 2014 | Olympus AS-2300 PC Transcription Kit
Pro-digital voice recorder sound
For all information about dictation and transcription please visit www.dictaphones.com, alternatively simply ring Speak-IT on (0121) 456800. Their team of specialised staff with over 30 years of experience in both dictation and transcription will be more than happy to assist!
Oct 24, 2012 | Olympus DS-3500 ODMS Pro Digital Voice...
We are experiencing issues within the AS-5000 transcription software for our Olympus DS-5000 recorders. When a typist selects the status of the file (''pending'', ''finished'', etc.) an error message pops...
Jun 04, 2009 | Olympus DS-4000 Digital Voice Recorder
No disc
You can download it here at this site.
http://www.olympusamerica.com/cpg_section/cpg_downloads.asp
Good Luck
Please Rate FixYa!
Dec 19, 2008 | Olympus DS-4000 Digital Voice Recorder
Olympus AS-2300
The new DS-5000 SW has still got some quirks. The RS-25 is no longer available and I too have had issues with the 27. If your PC has a serial port try the serial plug, I know it is a step backwards but it has worked for me several times. Hope this helps. For now I steer clear of the DS-5000's.
Jul 13, 2008 | Olympus DS-40 Digital Voice Recorder
Foot switch will not respond.
The answer is all in the serial number you use to install the DSS player!
Look carefully and you will see the recorder disk has in my case an [E] printed above the install serial number and the transcription pedal has [T]
Install the same disk with the E the driver is there, the control in Control Panel is there, but the foot switch does not work with the software. Put in the serial number with the [T] and foot switch works first time!
If you uninstall the play and then reinstall with the [T] serial number you do not need to reboot or even unplug the foot switch from the USB.
Bingo
Feb 13, 2008 | Olympus AS-2300 PC Transcription Kit
Olympus DM-20 Digital Voice Recorder Logo
1,015 people viewed this question
Top Olympus Audio Players & Recorders Experts
Ekse
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
