Question about Microsoft Word 2003 for PC
Printing problem in Microsoft Word 2003
While printing document in mircrosoft word, bottom line of page border not getting printed
Posted by sapanalaru on
Dave Herard
  • 152 Answers
Does the bottom border show up in Print Preview? Some printers will not print the full page, to include the border if it is too close to the papers edge. If you adjust the border to be further away from the pages edge, it should print. Instead of applying a page border, you may have to draw a border using a rectangle shape and apply the desired line style.
You can also try to adjust the border margin to measure from "edge of page" instead of measure from "text". This setting is on the options button located on the page border tab under the Borders and Shading window. This may allow you to adjust the margin enough to be able to print the border.
Posted on Apr 10, 2009
How do I print without a border please 8.3 by 11.7
Margins are set up in your WORD processor. Presuming you are sung WinWord, you should seelct
PAGE SETUP
and succesively adjust Margin, Orientation and Size.
Be careful that size of paper seelcted be the same size of the paper you are sung.
Microsoft Word tutorial How to print booklet lynda com
MS Word Print Preview Tutorial
Word 2013 Tutorial Previewing and Printing Documents 2013 2010 Microsoft...
Word 2010 Tutorial Previewing and Printing Documents 2010 Microsoft...
Sep 24, 2015 | Office Equipment & Supplies
How do you make lines appear on an excel sheet?
I'm not sure what Version you're using, so I'll assume after Excel 2010.
At the top of the page, under the Home tab and directly under the Font window, there is an icon which looks like a window frame (dotted all around except on the bottom edge).
In your spreadsheet you have to select the area you want to work on. You can select a single cell to add lines to or the whole spreadsheet. Click on the icon I described above and a menu box will pop down. There many choices which allow you to select lines on all sides of your work. I prefer the one at the bottom which says 'More Borders'. With that window you select the edges you want lines on, the thickness/type of the line, or put an outline.
I think that's enough for now and I hope that gets you started.
Aug 12, 2014 | Microsoft Excel 2010
CANON IP 4300 PRINTERS WILL ONLY PRINT ALTERNATE LINES
I think your text document didn't fit the page. I have done that before. It overruns and the extra becomes the lines inbetween. To fix this use microsoft publisher to print it so that you can choose the paper size and the borders and fit the document within the space allowed.
Nov 24, 2013 | Canon PIXMA iP4300 InkJet Photo Printer
WILL ONLY PRINT EVERY ALTERNATE LINE OF TEXT & TEXT BOX BORDERS
Doesn't sound like your printer hardware. Try printing something other than your text document. If the page comes out clean/perfect then it means your printer is having a problem understanding your text document via print program translation. Otherwise try converting your text to pdf and print a sample page, if it works then again problem with software/printer translation.
Nov 24, 2013 | Epson Stylus CX3810 All-In-One InkJet...
X4650 not printing footer correctly
Most printers have a no print border roughly 0.6 cm around the page.
You may be able to set the printer to "Edge to Edge printing to get around the no print zone.
Don
Oct 23, 2009 | Lexmark X4650 InkJet Printer
Can't find program for borderless printing
You need to really defining "Border-less Printing". Are you speaking of printing border-less photos? Or do you mean border-less documents.
Border less photos are usually set up in the printer's driver, providing that the printer's hardware allows this function. Some printers, especially older models, cannot print to the edge of a page by design.
Don
Aug 16, 2009 | Brother MFC 6490CW InkJet Printer
HP4000n (Not printing borders on Excel and Word)
this is because your document content is out of range for your printer settings
clik on file - page setup and adjust your document properties from there
Jul 24, 2009 | Office Equipment & Supplies
No bottom page border
Apr 06, 2009 | Microsoft Office Professional 2007 Full...
BOTTOM BORDER LINE IS NOT PRINTABLE
first you must see the printpreview before you print the documents you want to print so that no error upon printing the hardcopy,
hope it will help...
May 28, 2008 | Microsoft Office Computers & Internet
Microsoft Word 2003 for PC Logo
484 people viewed this question
Top Microsoft Computers & Internet Experts
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
ThaMp3Doctor
ThaMp3Doctor
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
