Question about Toshiba 27AF42 27" TV
Zenith Advanced System 3 console tv wont turn on SG2721H
2 Suggested Answers
Anonymous
SOURCE:
Keyosuke
  • 4 Answers
SOURCE: zenith advanced system 3, can't access video 1 or 2
I just got the TV for free with no remote and had the same problem.  The solution I found is to connect two devices that are feeding live signal (a VCR, DVD player, or game console) to the RCA connector input on the back of TV for Video 1 and Video 2.  I then used the first menu option which I accessed by using the Menu key on the front of the TV and Adjust and Select buttons to scan for channels and detect the band for the reciever to use.  After doing this I changed the setting away from "Fixed" (I forget which setting) and turned the TV on and off.  I then found that by pressing Menu several times I would get new menus.  Before I had done that scan with more devices attached to the other ports I didn't get any other menus.  I also discovered that depending on which devices I had connected I would get a Picture in Picture feature.  It would have its own menu to select its source, but I would lose that feature if I changed the device topography of my setup.
Posted on Jan 19, 2009
Can i use an rca universal remote to use my older zenith advanced system 3 tv
You can if the RCA universal remote is compatible, i.e., contains the appropriate code.
Oct 12, 2017 | RCA Televison & Video
No power when television is turned on
1) test the outlet box and plug a desk lamp if work, if does the circuit is o.k if NOT reset the c.breaker from your home
2) test the power cord for open or break
3) see for a blown fuse inside and replace, or c.breaker tripped reset.
4) test for short in transformer+coil+filter+diode+rectifier and ground chassin.
5) test the Horizontal output for +125vdc +HVREC+FLYBACK+vertical output for 80vdc+all they go to the CRT. measure the color circuite +12vdc+other circuite+12vdc+audio 24vdc. see the block diagram oTHERWISE you must to the repair shop TV
God bless you
Jul 31, 2012 | Zenith Televison & Video
Where can I get a manual for a 1986 zenith system 3 tv set
LG owns Zenith. Go to there website and you should be able to download the manual.
Nov 20, 2009 | Televison & Video
Zenith system 3
There is a fuse located near the power cord just inside of back panel ,check it first. Please rate !
Jun 24, 2008 | Zenith C27A24T 27" TV
Zenith Remote controller
It's a Zenith remote, MBR 3440 is the model #, 124-202-01 is the part #. To program, press and hold PRG button until red light stays on, press TV,AUX etc, enter 3 digit code (www.xdiv.com) press Enter.
Jan 10, 2008 | Zenith HCS3000R Headend Controller For...
Zenith System 3 25" no audio picture ok
If you have satellite try unplugging satellite receiver. If doesn't work you probably have a audio output ic bad inside the set.
Dec 31, 2007 | Zenith Z25A66R 25" TV
Zenith advanced system 3, can't access video 1 or 2
Sep 09, 2007 | Toshiba 27AF42 27" TV
Zenith Advanced System 3 not working
your tv is in EYE PROTECTION MODE... NO JOKING... You might have damaged capacitors inside near the tv CPU and in the main power supply. Pleasecontact a good service tech for repair Patrick
Aug 27, 2007 | Televison & Video
Zenith system 3 tv will not turn on
I'd say just get a stereo system (amplifier) or something like that, and hook your cable box, vcr, converter or whatever you have right into that. That's what I've been doing for years. Most cable boxes and satellite boxes will control the main volume that goes to the sound output, or you can get a digital stereo with a remote to control the volume that way.
Oct 26, 2006 | Zenith SY3538RK TV
Toshiba 27AF42 27" TV Logo
67 people viewed this question
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
