Sounds like it may be your left CV Joint. if it is you might as well change both sides since they have the same amount of milage on them.
A total CV joint failure = Tow to the shop. Good luck and hope this helps
A wobble in the steering is more likely to be one of
- loose wheel nuts
- loose hub nut
- worn steering tie rod outer joint
- worn steering tie rod inner joint
- loose steering rod universal
- worn steering knuckle ball joint
Out of these a worn or loose steering tie rod joint is most likely. If you can, jack the front of the car up and rest it on axle stands, NOT just on the jack, then have one person shake the front wheel back and forth while holding it at 9 and 3 o'clock, while another holds the steering wheel still. Then look at and feel each joint to see if you can locate the looseness.
CV joint - wheel side needs to be replaced :) right wheel, a lot of people drive like that for a while before they fix it so don't worry, also it shouldn't be soooo expensive
Jack up the wheel and see if it has play up and down and left and right. Have someone watch inboard as you move it. A bad cluck will usually show itself.
