Take out the right front burner and use your multimeter to check it for continuity. Only then can you be sure that the error code isn't lying to you.
It is my guess, that with an error message so specific, that if no burners are working, it is not the front right burner at all. Hands on testing is the only way to be sure.
F152 means the right front burner has failed
, the sensor in it is bad, the burner will need to be replaced.
The element is $225.00 so it is not something to change on a guess. Full testing procedure here, or call for a Service Engineer.
https://www.appliancepartspros.com/answers-for-ge-element-radiant-lt-wb30t10080-ap3188020-question-148609.html
