Question about Ecoquest Flair Air Purifier
Flair sparking My Flair unit is sparking to the point of annoyance. I've cleaned the plates but it still continues..Is there anything that can be done? thanks Jay!
Posted by jau falcone on
Glen Coleman
  • 80 Answers
Contact [email protected] They will be glad to help you.
Posted on Apr 15, 2009
I have an older model Flair unit. I took it apart to try and give it a good cleaning and noticed that there was a small glass bulb-looking part with one of the thin wires was broken. Of course the other...
It's attached to the pulse radio-wave ionizer. It comes on when the unit is on to show the radio wave is working. It's not needed and I've never seen a replacement but Radio Shack could probably help you replace it if you wanted.
Jun 23, 2011 | Ecoquest Flair Air Purifier
There is a blue spark and bug zapping sound-looks like its sparking on the ceramic ozone plate. The place looks fine-no cracks.
It's doing exactly what it's supposed to do. The bug zapping sound is from dust particles in the air, that's being pulled thru the unit. However, it should not being doing in continuously (unless your home is really dusty), it may simply need cleaning. Cleaning the unit, about once a month is recommended.
Hope this helped you.
Jun 16, 2011 | Ecoquest Flair Air Purifier
My Flair smells like it is burning and the plates are making a loud sparking sound
What's burning is probably your high voltage transformer. When your glass plates get a crack in them, they will spark. You probably have a burned out high voltage transformer. That's what produces the ozone. Helpful hint...........the high voltage transformer is also the one used in bug zappers
May 01, 2010 | Ecoquest Flair Air Purifier
HELLO AND GOOD MORNING I HAVE A FLAIR AIR
Open the back and change the Ozone plate. then slide out the ION plate and clean it with denatured alcohol. If no light inside, you may have to replace the bulb and / or starter. Hope that helps.
Mar 18, 2010 | Ecoquest Flair Air Purifier
Sparks shooting down sides of ozone plates
Disconnect the power and give it a good cleaning with a SOFT BRISTLE PAINT BRUSH. Outside is best. Blow it out gently with canned air after you brush the dirt loose.
Jul 25, 2009 | Ecoquest Flair Air Purifier
How do I clean the metal screen? Do I need to replace any filters at any point?
if the metal screen is removable, run under warm water and gently brush with damp rag
if no removable, unplug unit, wipe clean with damp rag
May 29, 2009 | Ecoquest Flair Air Purifier
Ecoquest Flair Air Purifier leaves black residue on walls and...
The black residue is what is in your air. The reason for it to cling to the walls is the Ionization process that the machine creates. The ionization is to create a clean breathing space, free from contaminants. All particles floating in the air will be negatively charged and cling to each other or to objects in the room (like walls) that are positively charged.
If you cook, there is some smoke created, or when you burn candles. These greasy particles will stick to the wall or to surfaces. Cleaning them up regularly might help. You can also try another product from EcoQuest called EcoH which is based on enzymes and cut through that grime easily. That might take the black stuff off the walls.
Dutch
Mar 01, 2009 | Ecoquest Flair Air Purifier
Sparking
You got new plates they offer no support by phone? Could be some kind of dirt or contamination, the transformer could be shorting or sparking, write me at [email protected] or look me up on allexperts.com, it may be worth mailing to me and let me estimate repairs,
Nov 11, 2008 | Ecoquest Flair Air Purifier
EcoQuest Flair Air Purifier
get more distance from the two sparking points....with the power disconected, pryde the two metal points apart as mach as possible..to a quarter of an inch!
Nov 14, 2007 | Ecoquest Flair Air Purifier
Ecoquest Flair Air Purifier Logo
189 people viewed this question
Top Ecoquest Air Purifiers Experts
CheckitRight
CheckitRight
Mike Wilhite
Mike Wilhite
Level 1 Expert
Are you an Ecoquest Air Purifier Expert? Answer questions, earn points and help others
