Question about Proview PL713S 17" Flat Panel LCD Monitor
Display comes on for 5-10 seconds and then black.Power led is on all the time.Switch off monitor and switch it on Display again comes on for 5-10 seconds.Semiconductors on Inverter board are ok checked by replacement.Problem is on the power/inverter board panel is tested known ok. Any help appreciated.
1 Related Answer
Anonymous
SOURCE: BenQ FP51g LCD monitor
Dear Friend:
There is a Switch transistor to power on -off the hi voltaje for lights. Check 15V from power source go to this transistor colector, Using soldering Iron, make a juntion between colector and emiter, to short 15V to Hi voltaje power. I´m fixing 10 monitor the same trouble. I will remove a liter transistor.
Late I will post here the driver transistor number, and the replace number transistor I will use.
Pictures , etc. Best Regard
Posted on Oct 25, 2008
1) when i switch on my hp L1906 19" LCD monitor display comes for 2 sec. or 3 second then it goes blank. then i have to switch off and again switch on but problem remain like that... 2) in my second...
this question is posted here 100 times, search much.
the CCFL tubes are burned out
as all do ,every 20,000 hours, 5 years old if run 10yrs a day.
all do,
until 2010 when LED BACKLAMPS HIT THE STREETS
POST 101.
Also the internal power saver must be turned off.
menu button, turn it off. on OSD
Jan 26, 2018 | HP L1906 19" LCD Monitor
Motherbord run but not dishplay
MY DEAR FRIEND
CAN you tell me the what is the display problem
OK
Apr 11, 2011 | Intel Motherboard
I have a samsung syncmaster t240 monitor. Boots up normally but the desktop appears for a brief time (1 second) then goes black. I used the torch technique and saw the desktop icons. When I switch the...
I believe the power led button is still on while the screen goes black, if yes, it means the picture board of your monitor is bad that is why it appears for a second and goes black after that
Since the power led button is on, It means the picture board on your monitor is faulty that is why it appears for a second and goes black.
The best thing for you to do now is to take the monitor to a local repairer or any service center within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself in other to complicate issues.
Take care.
May 01, 2010 | Smart Modular SV3170A
Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
Benq FP71G+ 17" LCD with Power Recycle (shutdown & return).
Seems either aproblem with Invertor board or Front panel switches are leaky.
Samir
Aug 17, 2008 | BenQ FP71G 17" LCD Monitor
IC POWER CM2017 LCD MONITOR
Normally when this type of problem happens, the first suspect would be the inverter board, then the filter capacitors and lastly the mainboard.
A defect in one of the lamps and faulty inverter IC may cause the display to shutdown as well. If the lamp is defective, it will send a feedback and cause it to stop producing output signal thus the display just shut off once you switch in ON.
Jun 24, 2008 | Gateway FPD2275W LCD Monitor
Does a bad power supply look like this?
i suggest that you buy a new monitor coz your current monitor is too old...there's some electric component is weaken...its better to buy new than to repair the old one..
Mar 08, 2007 | Mag Innovision LT776s 17" LCD Monitor
Proview PL713S 17" Flat Panel LCD Monitor Logo
Top Proview Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
RS Technology...
RS Technology...
Are you a Proview Computer and Internet Expert? Answer questions, earn points and help others
