Acer Aspire 3002LCi Notebook Logo
Anonymous Posted on Aug 21, 2013
I have a problem in my laptop screen (LED), A bright white dot appear on center of display...!
Hardware and networking
Level 2:
Scholar:
  • Expert 112 Answers
  • Posted on Aug 21, 2013
Expert
Level 2:
Scholar:
Answers
112
Questions
0
Helped
29172
Points
316
I have two of those spots one bright, and the other one a little less bright.
If it's possible I'm going to send it back for a replacement.
I have the "[Bug 6334] random HW watchdog reboots" on my device as well that is quite annoying.
1 Related Answer
elix0411
Jose Cada
  • 3530 Answers
  • Posted on Mar 02, 2011
SOURCE: Recently my acer laptop is
Welcome to Fixya
Sounds like you already have a bad LCD there. Try to do power drain on the laptop. This will drain remaining electrostatic energy of the board. Take out the battery and unplug the power adapter. Press and hold the power button for 10 secs. Put everything back in then power "ON" the computer. If same thing will happen then its time to replace the LCD.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
How to turn the brightness up on echo dot with clock
  1. Open the Alexa app .
  2. Open Devices .
  3. Select your Echo Dot with clock device.
  4. Select LED Display.
  5. Turn the Adaptive Brightness feature on or off, or drag the slider to change the brightness level.
2answers
HP Elite Book screen won't come on?
It appears to be a known issue
Fix 1: Hard reset your laptop
Remove the power, hard drives, the battery and any attached peripheral devices. Press and hold the power button for 60 seconds and release. Put your battery in and plug the charger. Then don't plug anything else.Nov 20, 2019
[Solved] HP laptop black screen - Quickly & Easily - Driver Easy
My echo dot LED display does not automatically dim or brighten. How can I fix it?
Unfortunately, it is not possible to adjust the brightness of the LED display on an Echo Dot. To increase visibility, you can place it in an area with more ambient light, or you can use a lamp or other light source to illuminate the LED display.
How can I adjust my probook 4520s laptop brightness
If your HP laptop has a dull screen, or if the screen is too bright to make out anything that's displayed, you may need to adjust the brightness to get your screen back the way you like it. You don't want to strain your eyes to see your screen, and the fix is really simple. It's about as easy as adjusting the brightness on a TV. You'll have your brightness set the way you want it in a few seconds.
credit: themorningglory/iStock/Getty images
Step Right-click on an empty space on the desktop and a drop-down menu will appear.
Step Click on "Properties." If the HP laptop uses Windows Vista, you'll click on "Personalize."
Step On the "Personalize appearance and sounds" screen, click on "Window Color and Appearance."
VIDEO OF THE DAY
00:01
00:59
Step Click on the arrow beside "Show color mixer."
Step Use your mouse pointer to move the tab on the "Brightness" scale to the left or the right to adjust the brightness and click on "OK" when you're content with the color.
Samsung laptop.a small white spot came.after restart it went away.any problem
There might have been a glitch on startup, the operational system can do strange things, probably nothing to worry about.
I want to improve brightness of my laptop.And model no is R517.
Do the following
To adjust the LCD brightness press the Fn + (Up) key combination or the Fn + (Down) key combination. The changed screen brightness is displayed at the center of the screen for a moment.
OR
1. Turn the computer on and press the F2 key when the SAMSUNG logo appears on the screen to enter the BIOS Setup. 2. Select the Boot menu and set the Brightness Mode Control item to User Control. 3. Press the F10 key to save the settings and exit Setup.
Pink dots on screen
Could be try connecting to an external monitor using the vga port. If the same problem appears on the external display the problem is most likely the video card. You may wan to update the display drivers.
1helpful
2004 Sony KDF-55WF655 LED TV. Blue dots grouped and sparce all over the screen. Some dots appear to be twinkling. Lower corner has bright cloudy display. Dots and cloudy corner display will change state...
Bad Light Engine Call Encompass Parts Distrubtion
1-800-638-3328 or Visit their website they will list Parts in stock for this Model. UED has light engines
1-800-648-6657 you can also Look them up on Ebay sometimes you can find Parts alot cheaper their.Part number#A-1084-662-A Pice $1,423.64 core fee $800.00 Part Cost $623.64
Screen displaying a thin white very bright horizontal line.... plz help
problem in vertical section.
1. Solder the vertical ic
2. vertical ic supply capacitor problen.
3. dry points in neck board.
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
