Cameras Logo
A
Anonymous Posted on Aug 21, 2013
Repair lens - Olympus Cameras
I need the outer glass for my sal18250, the lens fell of my camera and chipped the glass on the outside, the lens still takes pictures fine it just depends on the way concert lighting hits the lens.
Sorry, but it's absolutely not a DIY fix. Your lens must be professionally repaired and it will not be cheap.
Get an repair estimate and then decide whether to live with the fault or repair/replace the lens.
Drop my Nikon D100 camera with a Tamron AF 75-300mm LD lens...lens will not extend, stuck on 200mm. If is worth repair, or can I repair it myself?
First question "is it worth repairing" if it were mine I'd look to see what a new one is worth then divide that in half (cause that's what you might be able to buy a used one for) then figure about $120.00 for cleaning lubricating and adjusting the your lens. With your lens you know what you have, buying used might need the service. you are the one to decide. As for the second question "can I repair it myself" short answer no. If you have to ask if you can repair it then you don't have the necessary tools and general knowledge of how to dismantle and reassemble the lens (and have it work when finished). The lens took a hit and most likely set the inner and outer lens barrels out of alignment causing the inner barrel to slip out of its seal and or focusing gear and hang things up forcing it will break parts causing more repair costs. All else fails get an estimate before repair. Been there with a lens myself and after a couple a months without bit the bullet and had it repaired. Cheers best of luck
2helpful
2answers
I have a sigma 18-35. It has not been used in a while and mold has formed on the inside of the lens. How can I open it up to clean?
Hi
to remove the front lens you will see a ring that you can peel off and you will see
4 screws take them off and the front lens will come off
Displays lens error when turned on will not take pictures, lens wont open
Any camera repair guy can repair these. A store that specifically sells digital camera can repair these cameras easily. This is actually a common problem for this camera and its cousin, the m525.
I have been tinkering with theses cameras. The lens for the m425 (and m525 ) can be removed and repaired manually. Since I am a amateur, my success rate is about 50%. It all depends on how jammed the lens. If anyone has good technique in manually repair these, I would like to know.
The one good thing is that lens can be removed and swapped out with another from a m425/m525 camera. I would look for broken cameras on eBay, ones with workings lens to replace your non-working lens
2helpful
2answers
2helpful
My canon 24-105 lens was dropped in water and I want to service it. (The Canon service centre says they can fix it but at a high cost.) is there an assembly diagram or instructions
This is not a DIY repair. You need to have access to lens collimators and other specialist tools and also need to be able to remove and replace lens cement to have any chance of tackling this successfully.
The cost is high not only because some parts might need to be replaced but because the lens needs to be stripped down almost totally to ensure that no moisture remains trapped inside. Some of the materials used in the lens construction tend to absorb water and will either need to be replaced or removed and dessicated before being replaced. When originally built, most of the lens was assembled by robots but it's far more difficult and precise for a skilled human to dismantle and correctly reassemble a lens which will already have seen some wear and tear.
If every last drop of moisture is not removed then you can at the very least expect your lens to fog up regularly and to rapidly suffer the onset of lens fungus which will permanently damage the glass coatings. You'll also find that electronic parts will fail due to corrosion.
Sorry to be so negative but I've repaired (and also failed to repair) enough lenses in my time to have a good idea of where the limits lie in lens repair.
Your lens will cost around £800 to replace, so even if repairs cost half that then it's money well spent. Botched DIY repairs will leave the lens either worthless or completely uneconomic to repair.
1helpful
2answers
Canon SD 870IS - lens error
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
6answers
"lens error" on camera. Camera will not function.
Try helping gently the lens to extend completely, using your fingernails, if the lens still do not extend, then the lens cylinder must be taken apart and remounted, this is a job that must be done at a repair shop.
Lens repair
It would not be advisable for you to try and clean this yourself. Special tools are required to remove the optics safely. Canon USA will charge a fortune to make this kind of repair. I suggest you use the search on this site to find a repair person in your area. The proper facility will be able to clean your glass, rather than replace it.
Top Olympus Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you an Olympus Camera Expert? Answer questions, earn points and help others
