I just replaced some seals and the boiler valve in my Saeco Vienna Deluxe. The machine worked fine for two shots, and then extracted very slowly. The steam valve seems to work fine, but it acts as if there's low pressure in the brew group. Can you help me troubleshoot it?
I had the same problem the brew unit was block from many shot remove the little tube on top of brew unit be carefull after removing the 2 screw there a spring under the tube and glass ball clean it good
Hi You boiler is leaking. You need to replace the boiler. sorry. Your water hardness might be set to low if you have been descaling when it tells you to. Boilers usually last 7 to 10 years, but need to be replaced. If you need one let me know. I have some new and rebuilt boilers for that machine.
I would repair it, it sounds like the grinder needs to be adjusted (burrs may be dull), and the leak on the bottom may be coming from the small drain hole on the back of the brew chamber. If you remo;ve the chamber you will see the white water valve that the chamber connect to, if you look below the white valve the small chamber in there will be filled with water, below that there is a small discharge use a stit stick or paper clip to clear hole.
Try this, open steam wand, if it calls for ventilate pusi in steam knob, if that works then the tap rod on the steam valve needs to be replaced. To me it sounds like the machine is building up pressure and the discharge is not releasing through the water circuit.
The factory setting should be 8. The higher numbers are finer. The + and - knob is the doser amount, the amount of coffee in a shot dose. Average is 7 gm, the middle. The highest is 14, I think. Generally, the highest dose shouldn't be used consistently because it can cause stress on the brew group. Just brew two shots.
Hi They should have checked the temperature before shipping it out. There is a sensor on the back of the boiler that has (depending on how old the machine is) 2 orange wires. In the wire or on the wire is a resistor. You can remove the resistor and raise the temperature about 6 to 12 degrees, but I think you need a new sensor.
If it will make coffee then you have a horse shoe boiler blockage or a steam valve blockage.
Try descaling first. If this does not work you will have to disassemble machine and trace the water lines back from the steam wand to the high pressure pump to detrmine where the blockage is. This can be trickey and is best left to someone with experience with this type of fix.
Contact saeco in Vancouver.
