You have one of 2 problems, an open Thermocouple or a bad control panel DISCHARGE high voltage components first with no power applied prior to
touching anything in the unit. Failure to discharge High Voltage
Components can result in death
go to applications, utilities, and open terminal
in the window, paste this: open /Library/Printers/Lexmark/Drivers/.Resources/
It will open the folder where the missing component should be. You will find the "2600 Series Color 1.lut" file. Duplicate it and change the name to 2600 Series Color 2.lut
close the folder, and shoot a print, it should work.
hi,
This is related to bad DCOM settings. Use the fix below to resolve the issue. Use the run command: Open "DCOMCNFG" to open up the Component services Expand `component services' and `computers' and right hand click on `properties' This would open the properties for My Computer and click on "Default Properties" Ensure that Default Authentication Level is "Connect" Default Impersonation Level is "Identify" Good Luck!
Some computer display this message when the case has been opened. After installing components in your computer and closing the case/cover then go into the BIOS setting and reset the chassis intruder detector.
hello sir
the software version you installed has changed your registry components ,
so plesae use a good registry clean up software, such as c cleaner rtc
Check the file extension.
This occurs when you don't have a program which can support the type of file trying to open.
Try opening with some program or chage the extension of file if it is not proper or install appropriate software supporting the filetype.
2. Re install media player on control panel add remove programs uncheck and recheck media player on add/remove windows components and click next... then re-start your system.
3. Download your version of Media Player or an upgraded one from Microsoft and install it.
hello hai
frist you goto control panel .add remove programs and addremove windows components and select widows media player exremove tik mork and next finesh
ofter this proses restar your system and same proses goto control panel and open addremove programs to select add remove windows components select the windows media player next finsh now your media player working fine
