Canon PIXMA  iP1800 InkJet Photo Printer Logo
Posted on Apr 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How to clear the error E007? The red light is on
How to clear the error E007? The red light is on and blinking but can't see any paper jam. Canon copier ImageRUNNER 2020
Anonymous
Level 3:
  • Master 1,219 Answers
  • Posted on Mar 02, 2010
Anonymous
Master
Level 3:
Answers
1219
Questions
Helped
673786
Points
2880
You cannot clear this error, you need to replace the fixing film.call service
Epson L361 Service Required Solution Red Light Blinking
The Epson printer red light blinking due to various reasons. The Epson printer light blinking when you have paper jammed, low ink tank, Epson printer printhead overloaded, when printer fuser not working and more.
Fix the Epson printer red light blinking error with simple methods:
·Clear Paper jammed in printer
·Check printer Ink cartridge
·Check printer network connection
Follow the more troubleshooting methods to fix the Epson printer red lights blinking issue.
My canon 2870 machine show paper jam and red light blinking
have got the manual for that machine ? it should explain how to remove paper jam if not you will have to remove the paper feed roller and carriage to clear it
7helpful
2answers
My canon iR 2022 is displacing the world System Error E007. If you put a paper, it also jams. What to do please ?
Canon fuser technology is hp laser printer system.This copier has a fuser film or eleventh cover.Some times its torn or short then this machine say E007.Its an error code.When occurred this E007 you should defective film.
When i hit "print" the
Does the red light blink or stay on sterady?
Issue: The Compact Photo printer power button is blinking red.
Solution: Turn the Compact Photo printer off, then back on again.
"Paper Jam" appears on the digital camera LCD Turn the printer off and disconnect the power cord from the printer. Then reconnect the power cord and power on the printer. If the printer fails to eject the paper, the printer may require service. Contact the Canon Customer Support help desk for assistance.
When you power down I would recommend also unplugging the printer from the power supply (wall outlet). Let it rest 5 - 10 minutes and then plug back in.
The manual says a blinking red power light indicates a problem in the printer, but the only solution provided it to turn off and on.
If there are no paper jams, and no other error messages hoepfully a completr power down will clear the error.
Issue: Printer's power button lights red without the camera's LCD monitor displaying any error message.
There is a malfunction in the printer.
Remove the paper from the paper-handling slot and take up any slack in the ink sheet. Turn the printe's power off and turn it on again.
If none of this helps I would check to see if my driver is current:
http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/selphy_compact_photo_series/selphy_cp510#DriversAndSoftware
Trust this is helpful. Please vote. :)
1helpful
Canon imageRUNNER 2020i left door paper jam error.how to reset Tried to clean everthying,and there is nor paper jam.
I have a Canon ImageRunner I seem to have a paper jam. The red light is coming on showing the jam in the upper section of the machine but I have cleared all the sections I know to clear. I have turned the machine off and back on the jam light is still on. I can't find the Manuel to see what the problem is. What should I do?
I have System error E007 problem in my Canon iR-2016 copier machine?
Hi
Thanks for using FixYa. Error E007 means there is a jam in the Fixing/Fuser Assy. Error E007 is related to a non-detection of the Fixing Film/Upper Roller, the fixing film sensor didn’t detected the rotation of the film for 6 sec or more while the fixing motor is driven. Please check the condition of your Film also check the green handle in this area for paper jam removal if it is broken or removed, may also cause this error. If everything is fine then try clearing the error by entering the service mode, you can do it by pressing *(star), then press 2 and 8 keys at the same time & then press *(star) again.
Now press COPIER>FUNCTION>CLEAR>ERR, to clear the error code.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
2helpful
2answers
Canon imageRUNNER 2020 error E007. What is the
An error in the rotation of the fixing film is detected.
The reading of the main thermistor is 100°C or higher and, in addition, the fixing film sensor does not detect the rotation of the film for 6 sec or more
I think - The fixing film sensor is faulty.
Caution To clear the error, execute the following in service mode:
COPIER>FUNCTION>CLEAR>ERR.
4helpful
2answers
Canono ir2016 system error E007
Fixing film has been displaced e007
Having too much paper in the paper tray will cause your printer to have more frequent paper jams and double printing. Make sure you fill the paper to the fill line. I usually recommend going a little below line. I would also recommend that there is no paper from your previous jams still stuck in there. That will cause it to jam up as well.
old marine
old marine
ZJ Limited
ZJ Limited
