SOURCE: Shutter won;t open
Are you talking about the shutter, or do you really mean the automatic lens cover ? Take a look at this first to see if this is what you meant. Make sure you read the comments also for additional tips. I don't think it will be necessary to open it up to fix it. Stick with the easy tips, they should work, especially if this is happening occassionally:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
SOURCE: microSD atchment write protect
The microSD card has no visible write protect tab that you can access: you need to use a Micro-SD to SD/mini-SD adapter that usually comes with your Micro-SD card and use the ON/OFF sliding tab on the adapter to disable or enable the wiite protection on your Micro-SD card: test the access via the adapter card before removing it.
Hope it helps: let me know how you go!
SOURCE: I cANNOT OPEN THE LENS OF MY CAMERA. OLYMPUS TOUGH
Apparently some problem in the inside of the camera with the lens assembly or something is disconnected. You can get in touch with the repairs of the Olympus company and see what repairs would cost. I am almost sure that the repair is going to be more than the camera is worth to you.
Many times dirt or dust can cause problems with the lens. Also this can be caused by internal problems which means repairs. In my experience with these small cameras, the lens repairs have been some of the hardest repairs to complete correctly. That is not saying that it cannot be done. If the lens is taken apart or removed, the camera should be re-calculated on a computer with the right software.
SOURCE: My Olympus Tough 8000 charges up to a blue light
i have the same problem too. Mine is mju tough 6010 and it just beeps and switch off. The metal cover in front of the lens won't open. Mine is just 1 month old.
