Re: toshiba BD-7610 copier moved the copier down a
Take the developer unit out carefully shake back and forth free spin the gears by hand clean any spill inside might work in the future remove dv and drum b 4 moving
That leaves a huge grey area. Help us help you. Are you looking at the zone panel? Is zone 1 upstairs? Does red mean powered when closed or opened? Are other zones cooling? Does zone 2 turn red AND when. Model numbers...
It sounds like you need to re-adjust your convergence. The purpose of adjusting your convergence is to align your red, green, and blue colors. Moving your TV often causes this problem. I hope you get it going.
have you check outlet with a voltmeter or even checked breaker? Is your new rect' a 3 or 4 prong outlet? If you hooked up red's to black and black to reds it still should have worked. The 220 volt heating element is between the red's and blacks the 110 circuits would be between a red or black to white wire.
Repair solder joints on convergance IC's,but your best bet is just to go ahead and have them replaced.I highly advise that a TV tech preforms the work.
Honestly, the best way to do this is to call an expert because any wrong adjustments to a treadmill can cause serious damage but if you want to attempt yourself you must try to move it whole with 2 people stronger holding the front of the tread as this is going to be the heaviest. Take the front down first down the stairs.
you should be fine as long as you don't drop it of course. you and turn and twist it any which way but id say measure the height of the tv because at some point you will have the top and bottom of the tv touching 2 different walls if im not mistaken
If it looks like the picture is yellowish all through it, then you will have to have the coolant replaced in all three CRT's. It is not unusual for algae to grow in the resivors.
