Question about University Games Five Little Monkeys Game
Instructions for Five Little Monkeys card game
2 Related Answers
Anonymous
SOURCE: instructions for 5 little monkeys game
Yohttp://www.universitygames.com/rules/university_games/FiveLittleMonkeys_Rules_01320.pdfu can get a copy of the directions at
Posted on Nov 08, 2010
derik purlee
  • 110 Answers
SOURCE: i need the instructions for
Where to begin? How about the board design and its effect on the game objectives. The game requires the completion of two conditions for a win: you must have collected four separate tokens and placed four plastic monkeys on top of the large bed in the center of the board. You accomplish this by spinning a dial on a cardboard wheel and advancing 1-6 spaces along a rectangular track, landing on either an image featuring one of the four tokens or a "monkey space" which allows you to place 1-3 monkeys on the bed. There are a couple of issues here - the board is designed in such a way that, with one or two exceptions, you will always land on the same space every time you spin a '5.' In other words, if you just collected the "teeth brushing" token, spinning a '5' on your next turn will bring you to the next "teeth brushing" token on the board. If you spin another 5 on the following turn, the same thing will happen...and so on and so forth. This doesn't sound like too big of a problem, until someone spins '5' four times in a row, effectively missing three consecutive turns, as advancement in and of itself doesn't really achieve much.
This is further compounded by the fact that monkeys can be knocked off the bed, in a manner similar to some other classic games. At the end of each player's turn, that player must press a button on the bed, and every few turns the mattress will bounce up, knocking a few monkeys back off the bed. This can be very frustrating under the right conditions, and can greatly extend the length of the game if it manages to keep victory out of reach that much longer for all players. It gets worse the more players you add to the game (up to a maximum of 4). It isn't much fun for anyone when a player spins 5 a couple of times in a row and then proceeds to knock all of his or her own monkeys off the bed (happens more often than you might think).
Perhaps the worst part of the game for younger players is keeping them on track throughout their turn. Most games for very young children are set up so that a turn has two steps...three at most. Generally speaking, you roll something or spin something, and then either move your piece and react to that movement or simply react to the result of the spin/roll. In Five Little Monkeys, the child must spin the wheel, move the monkey, place monkeys on the bed OR collect a token, press the button on the bed, and then collect any of their own monkeys that have fallen if the bed sprang up this turn.
good luck!
Posted on Jan 29, 2011
What are the rules?
Place one monkey for each player on the starting square. The other five monkeys for each player start in front of the players.
  • Place one monkey on the bed at the beginning of your turn. University Games recommends the youngest player start, followed by the next youngest, and so on.
  • Flick the spinner to choose randomly the number of spaces to move. Move your monkey that many spaces on the game board.
  • Perform the indicated action on the game board. The actions include bathing, dressing in pajamas, teeth-brushing and going to bed. Act out the actions similar to charades. Once the action is completed, place the corresponding action token in front of you. If you land on an action space you already have a token for, perform the action and the rest of the steps as usual, but do not take a token.
  • Place one monkey on the bed at the end of your turn. If you landed on a space with a picture of monkeys and a number instead of an action, place the number of monkeys indicated on the bed. If you do not have that many monkeys left, put all your monkeys on the bed.
  • Press the red bedpost to end your turn. Pushing the bedpost not only indicates the end of your turn but it also triggers a random action. Occasionally, the bed will shake. If your monkeys fall off, put them back in front of you. If they fall over but do not fall off the bed, set them up right again.
  • As you move around the game board, if you pass the start square, place another monkey on the bed. Repeat steps 2 through 5 until someone has all four action tokens and a minimum of four monkeys on the bed, winning the game.
  • Aug 11, 2012 | University Games Five Little Monkeys Game
    Are there printable instructions?
    unfortunately, there is no way to print out instructions. You could make copies of the instructions, or scan them then print them. I hope that helps
    Sep 17, 2011 | University Games Five Little Monkeys Game
    I need the instructions for five little monkeys
    good luck!
    Jan 23, 2011 | University Games Staying Alive Murder...
    How to play
    Hello there!
    Do you know that? The longest recorded game everto play the Monopoly game is 1,680 hours - straight!
    Here's the instructions:
    1. Keep in mind that the ultimate goal is to have the most money and assets at the end of the game.
    2. Make sure that you have all the pieces. The box should contain a game board, two dice, play money, 32 houses, 12 hotels, 11 tokens, a stack each of Chance and Community Chest cards, and a Title Deed card for each property.
    3. Lay the board out with the Chance and Community Chest cards facedown on their respective spaces.
    4. Choose your favorite token. Put all of the Players' tokens on Go.
    5. Select a player to be the Banker. This person takes care of the money, buildings, and Title Deed cards.
    6. Distibute the money. Each player gets two $500 bills, two $100 bills, two $50 bills, six $20 bills, five $10 bills, five $5 bills and five $1 bills for a total of $1,500.
    7. Have each player roll the dice to see who goes first. The highest roll wins, and play moves to the left.
    8. Roll the dice and move that many spaces.
    9. Buy a property from the Bank, if you wish, when you land on it. If yo opt not to buy a property on your turn, the Banker may auction it to the highest bidding player. Bidding can start at any price and anyone may bid on the property.
    10. Pay rent if you land on a property owned by another player. He or she must remember to ask for it before the player after your throws the dice.
    11. Take a card if you land on Chance or Community Chest and follow the instructions.
    12. Keep the dice if you roll doubles - once your turns is over, you may roll again.
    13. Go to Jail if you roll doubles three times in a row.
    14. Collect your salary of $200 from the Bank everytime you pass or land on the Go.
    15. Get out of the Jail by any of these methods: Use a Get Out of Jail Free card; pay a $50
    Nov 13, 2010 | Monopoly Games
    Lost my 4 released monkeys!
    I have a similar problem, I saved and now cannot get to the other side of the bridge, can anyone help please??
    Mar 24, 2010 | Nintendo The Legend of Zelda®: Twilight...
    Instructions for 5 little monkeys game - have all the pieces not sure how to play.
    Apr 28, 2009 | University Games Five Little Monkeys Game
    Wii got find for monkeys which are the kid fund all but one
    There are a lot of monkeys! If you look at your dungeon map, there should be a symbol indicating where the monkeys are, I think it is a little red cage but I don't quite remember. You might need the compass for it to show, so make sure you open all the chests and check all the rooms.
    Apr 05, 2009 | Nintendo The Legend of Zelda®: Twilight...
    Shrimp Instructions?
    Hi brine shrimp are sea monkeys just google see monkey hatching instructions they will be the same. my instructions do not have the information either but my set came with the brine shrimp. you just wont have pouch #1
    http://www.discoverthis.com/sea-monkey-instructions.html
    http://www.discoverthis.com/seamonkeys-hatching-temperature.html
    Good luck we had 4 generations of sea monkeys. When they fie off you can let the water evaporate from your tank and Add new water and the cycle wiil start all over. we are in that process now 4th time...
    Dec 31, 2008 | Vivitar 900x 28-piece Microscope Set
    How to program fisher price interact tv with our dvd; do not have instructions
    Here is the link for manual. It comes in five little documents. If you need the whole manual download all five. Just takes a minute. Otherwise just click on each one until you find the one you need. http://service.mattel.com/us/product_detail.asp?id=B9376&Ntt=B9376&Pn=1&Brand=Fisher-Price+Technical+Products&Cat=InteracTV
    Mar 15, 2008 | Video Game Consoles & Games
    University Games Five Little Monkeys Game Logo
    239 people viewed this question
    Top University Games Toys Experts
    Marvin
    Marvin
    Tom Chichester
    ray gallant
    Are you an University Games Toy Expert? Answer questions, earn points and help others
