Very new to scanners have uniden BC95XLT. During scanning of 2 banks of channels I have manually entered, scanner stops and says found I have entered these channels and it will stop at this same freq again and display found. I thought you could not enter the same freq twice but it seems to allow me to enter it into the next bank even though the same freq is already in one of the banks.
This occurs during scanning and says found but most times it is finding a channel already in a bank. Have not spent much time to figure it out, but do not like that it locks onto the found channel and stops scanning, until I push scan again to restart scanning. It will also display found during searching. This scanner rounds freq off to nearest 5 don't know if trans can be like 123.322. First searching scanner I have ever owned. I am also somewhat electronically challenged. Mark
Yes it locks on blinking founf and dotted lines alternatly and stays locked until you push scan or push function and program very quickly then it either shows what channel this freq is already on or when you hit program or enter (same button) it will enter that freq into the next available spot in the next bank> But as I say I now have repeats of some channels and the instructions say that it should not allow me to double a freq. I am thinking it will not allow a double in the same bank but may allow it to go to a diff bank if you hit enter. I have to have surg in a month and will have more time to mess with it then. But as for now I have not even figured out how to delete a stored channel. Technologically Challenged. Thanks Mark
Are you scanning or searching? Not familiar with the word "found" when scanning programmed channels. You should be able to program the same frequency in another bank though.Are you scanning or searching? Not familiar with the word "found" when scanning programmed channels. You should be able to program the same frequency in another bank though.
You can't post conmments that contain an email address.
Push the "L/O" lockout button and it will lockout that channel.
When you press "Scan" you have to have at least one of the banks scanning, so press 1, 2, 3,....9, 0 whatever bank you have channels programmed in order to automatically scan. You should be able to press "Manual" to see each channel individually.
It sounds to me as if your scanner is locking on to a 'BIRDIE', which is an internally generated frequency in the scanner, all scanners have this by default, your user manual usually has a page, near the back of the manual, with known 'birdies', and there a lots.
When your scanner locks onto a 'BIRDIE', which is a frequency with no voice audio, the best thing to do is press Lockout button, during the scan, your scanner will, if there is no other problem with it, continue to scan, until it finds another 'BIRDIE', then you do the same thing as I've described, until you've locked out all the 'BIRDIES'.
what it is because that your other banks are locked out and thats why it by passes your frequencies...unlock your banks and it will stop on the transmissions...
Locking/Unlocking Banks
When you are scanning conventional banks, the scanner displays the digit corresponding to
all unlocked banks. To lock out a bank so that the scanner does not scan its channels, press
the letter that corresponds to the bank. The bank's letter disappears from the display.
To unlock locked-out banks, simply press that bank's letter again. The bank's letter
appears on the display and the scanner includes that bank when scanning.
Note: You cannot lock out all banks. One bank must be unlocked at all times.
Locking/Unlocking Channels
To lock out a channel so that the scanner does not stop on it while scanning, press L/O
when the scanner is stopped on that channel, or manually select the channel and press L/O.
To unlock the channel, manually select it and press L/O again.
Restoring All Locked Out Channels
You can restore all locked-out channels in a bank only when the bank is selected for scan.
Follow these steps to restore all locked-out channels in a bank.
1. If you de-selected the bank, press SCAN then press the bank's letter.
2. Press MANUAL.
3. Hold down L/O for about 2 seconds. The scanner beeps twice and unlocks all
To delete a stored frequency, press 0 then press E. Channels with no frequencies are automatically locked out hope this helps
To program a known frequency: 1. Power the scanner ON. 2. Press the HOLD key to stop scanning. 3. Enter the desired channel number. 4. Press the FUNC and PGM keys. 5. Enter the frequency, including decimal point. 6. Press E to enter the data into memory. 7. Repeat steps 3 through 6 for other channels.
More detailed programming instructions can be found in the scanner operating manual w2ich you can download/print here:
http://www.uniden.com/pdf/BC72XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
Major Functions of Uniden BC 855 XLT Desktop Scanner
RANGES AND MODES:
29-54 MHz; 137-174 MHz; 406-512 MHz; and 806-956 MHz NFM;
118-136 MHz AM
MEMORIES & MEMORY SCANNING:
• The 855 receives mainly via frequencies programmed
into its 50 memory channels. It does not have a VFO or dial
mode as such, but can scan within two frequencies.
• To scan memory channels, press SCAN. To hold a channel,
press MANUAL.
• The 50 channels are divided into 5 banks (Bank 1:
Channels 1-10, Bank 2: 11-20, etc.).
• Any of the 5 banks can be turned off from scanning.
To turn a bank on/off, press its number while in Scan Mode.
Active banks are illuminated in the display.
• SPEED toggles between 8 & 16 channels per second
in both scan & search modes.
TO ENTER A FREQUENCY IN A MEMORY CHANNEL:
• Press MANUAL.
• Press the channel number you wish to program using
keypad.
• Press MANUAL again.
• Enter the desired frequency using the keypad.
• Press E (ENTER). (If you make an ERROR, press CLEAR
& re-enter frequency.)
• To set 2-second delay, press DELAY. Confirmed by “DLY”
in display. Same deselects.
• To lock out channel from scan, select it & press
LOCK OUT. Same deselects.
PRIORITY CHANNEL: Press PRIORITY to scan Ch. 1 every 2 seconds.
TO SELECT CHANNELS MANUALLY:
• Press MANUAL.
• Press desired channel number on keypad.
• Press MANUAL. Press MANUAL repeatedly to step through
channels sequentially.
TO SCAN UP/DOWN FROM A CHANNEL: Select channel manually,
then press ? or ?.
TO SCAN/SEARCH A GIVEN FREQUENCY RANGE:
• Press MANUAL.
• Enter the lower frequency limit.
• Press LIMIT.
• Enter the upper frequency limit.
• Press LIMIT.
• Press SEARCH.
I couldn't locate the manual for your scanner, but it's basically the same as the BC860XLT, except that the 860 has 100 channels. Other than that, all controls and functions are the same. You can download and print the manual for the 860 here:
http://uniden.com/pdf/BC860XLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning info, visit:
To remove the lockout from a channel, manually select the channel, then press Func + L/O. L/O disappears.
To unlock all channels in the banks that are turned on, press Hold to stop scanning, then press Func and press and hold L/O until the scanner beeps twice.
