SOURCE: wiring diagram
Had a three prong plug and now the new apt calls for a 4 prong plug...which I have but no diagram to show which color goes where.
SOURCE: wires came unplugged from behind control knob
Below is the link to the wiring diagram to your dryer, it should help some. In addition what I can tell you is that most appliance components have initials next to the connections that indicate what color wire is supposed to be connected to them, this is where the diagram should help. In cases of things like switches, buzzers, thermostats, things that only have to do with circuits being open or closed they will not have an initial so therfor it doesn't matter what wire goes to what connection. Post again if you need more help. http://www.appliance-parts-warehouse.com/frigidaire-parts/Frigidaire-Dryer-Parts/Frigidaire-Parts-GLER331AS2/Frigidaire-Parts-50169.cfm
SOURCE: Wire Scraping sound and sparks inside rear dryer drum area.
Probably the rear bearing has failed and caused the drum to rub against the heating element. Hey, is this the guy that said he heard a noise last month? LOL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
SOURCE: My Frigidaire electric dryer GLER341AS2. The
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Testimonial: "I have cleaned the dryer inside out but will now clean from the wall to the outdoors and see if this solves the problem. Thanks for the suggestion."
