SOURCE: Amana AOCS3040 Convection Oven
If I were you I would contact Amana and speak to their service dept. and tell them your problem as maybe theres a service bulliten out or a common repair and if that they would recommend someone who can fix this model.. I tryed to look up this model and I couldnt find it. If that dosent help Go to http://repairclinic.com and ask the repair guru there for assistance.. Good luck
SOURCE: Amana Convection oven not controlling temp
I have just checked the baking guide in the manual and have found that it may not be us after all. (Maybe this is why they telll us to read the whole manual. Well, I never have) According to the cooking time for Baking, the range is very extensive. For example, an angel cake at 350 could take from 28-50 minutes, buscuits at 375-400 could take 8-16 minutes, layer cakes at 350-375 could take 25-40 minutes, pound cakes at 325-350 could take 45-70 minutes and fresh pies at 400-450 could take 35-60 minutes. Basically, the baking directions on the box means absolutely nothing to use Amana oven owners. We have no choice but to cook our food or baked goods until they are cooked, whenever that may be. :) Linda
SOURCE: On a Amana EvenAir convection Plus oven the
There is a blower on the top of the oven, which turns on when the oven is hot enough. If the warm/hot air is coming out from top vent corners - this is the blower working. Even if you turn the oven off at that moment, the blower will still work until the oven cools down. This is normal.
SOURCE: my gas oven keeps shutting off during
The ignitor is not working right and is going bad....
have
the repair man replace the ignitor, or DIY....
Check out this tip
about your problem...
Oven not Working or Oven
not Heating
Oven
Problems Replacing the Igniter
heatman101
SOURCE: my electric amana oven turns off after it has
Ovens have a thermal overload beneath the outer skin which prevents the oven from overheating. If the temperature in the cavity gets too hot the overload will operate and cut all power. When the oven cools down sufficiently the power is then restored. My guess is that this is what is occurring. If the electronic timer is faulty is doesn't normally turn off and on, it just won't work. It sounds as if the thermal overload needs replacing.
