Adobe Acrobat® 8.0 Standard Full Version for PC Logo
Question about Adobe Acrobat® 8.0 Standard Full Version for PC
Serial key for adobe acrobat 9
Please send me serial key for acrobat pro 9....I need imidiately,i have to submit my final assignment tomarrow.Pretty please help help help me.''Thanx a lot
i apprisiate that.
Thnax again
Posted by yaadhappy on
Anonymous
  • 99 Answers
Hi :)
Unfortunately i cannot provide you with a products serial number or CD-Key
What i can do is suggest a free ware version that i use and find effective
Foxit V3 Build 1506 Free PDF VIewer
http://www.foxitsoftware.com/downloads/ this is its homepage and the ONLY acceptable place to DL it from if you can. (Never go off another site unless its impossible to locate the home page of the sofware as the software may have been manipulated to be malicious and is offered by the other site only to benifit thier desires)
This software will allow you to view and edit your PDF files IMMEDIATELY and then you can figure out Adobe later :)
Please rate the helpfulness of this advice. It will help me :)
Brad
PS Comment if you need further assistance or this isnt the solution you need
Posted on Apr 09, 2009
4helpful
Can't save Adobe Acrobat 9 fillable forms
Fill in an interactive pdf form After you fill in the form fields, do any of the following:
  • Click the submit form button. Clicking this button sends the form data to a database across the web or over your company intranet.
  • In Acrobat, choose File > Save As, and rename the file to save the form with the data you entered.
  • In Reader, choose File > Save A Copy, and specify a location for the copy. Note: If the form author gave Reader users extended rights, the saved copy will include the entries you made in the form. Otherwise, the saved copy will be blank.
Enable Adobe Acrobat Reader users to save form data Ordinarily, Reader users can’t save filled-in copies of forms that they complete. However, you can extend rights to users of Reader 8 and later so they can do so. In Acrobat Pro and Pro Extended, these rights also include the ability to add comments, use the Typewriter tool, and digitally sign the PDF.
  1. Open a single PDF, or preview a component PDF in a PDF Portfolio.
  2. If you are editing the form, click Close Form Editing in the upper-right corner of the form.
  3. Do one of the following:
    • (Acrobat Pro and Pro Extended) Choose Advanced > Extend Features In Adobe Reader.
    • (Acrobat Standard only) Choose Advanced > Extend Forms Fill-In & Save In Adobe Reader.
    These extended privileges are limited to the current PDF. When you create a different PDF form, you must perform this task again to enable Reader users to save their own filled-in copies of that PDF.
If you don’t want recipients to overwrite the blank form template by saving form data, do not extend rights in the copy you send to them.
Limitations on saving filled-in forms locally
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended each allow Adobe Reader 8 or later users to fill in and save PDF forms locally. The use of the Reader Extensions capability for local saving of PDF forms (called extended documents) is limited in two ways:
Number of deployed extended documents An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to an unlimited number of recipients for them to fill in. For example, an Acrobat customer can post an empty form template on a web page that allows users to fill in and save PDF forms locally. An unlimited number of people can access the template. However, the Acrobat customer can collect only 500 responses from the filled-in form. This limitation includes both hardcopy (paper form submission) and electronic representations of the filled-in form.
Number of recipients of the extended document An Acrobat Standard, Acrobat Pro, or Acrobat Pro Extended customer can send an extended document to no more than 500 unique recipients. For example, an Acrobat customer belongs to an organization with 500 people or less. The Acrobat customer can send an unlimited number of copies of the extended document to those 500 recipients and collect unlimited responses from the filled-in form.
Both limitations apply per entity/company, and multiple users in an entity cannot abuse this feature. Obtaining additional licenses to use Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended does not increase the above restrictions. For example, five Acrobat Standard 9 users in a company cannot send out the same extended document to receive and extract data collectively more than 500 times.
Acrobat Standard, Acrobat Pro, and Acrobat Pro Extended include technology that can enable PDF documents with certain features by using a digital credential. This credential is located within the Software (“Key”). You agree not to access, attempt to access, control, disable, remove, distribute the Key for any purpose.
I hope it helps.
Regards
I want serial key of acrobat reader 9
The Adobe Acrobat reader is a freeware software so there is no need for serial key. Just visit Adobe (here is the link for the reader), download and install it.
In case of a problem or clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
1helpful
Need serial number for acrobat 7
Welcome to FixYa! Your serial number is unique for your software. If you go to Adobe support and follow the registration instructions your computer will be scanned and the serial number detected. There is also a toll-free support number if you wish to obtain a serial number that way. Another serial number will not help you and is against anti-piracy laws to post here anyway. Here is where you will find help: http://www.adobe.com/support/ Steve Medley
Top Adobe Computers & Internet Experts
David Shaub
Steve Nordquist
Steve Nordquist
George Etukudo
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
