Question about Kodak EASYSHARE G610 Thermal Printer
My near-new Kodak C315 printer keeps telling me "out of paper" despite being loaded, and won't print. Why? What can I do?
5 Related Answers
Anonymous
  • 6 Answers
SOURCE: Loading envelopes
To load envelopes that are under 7.87 inches (220 mm) in width in the multipurpose feeder, insert the envelopes with the flaps open and toward the front of the printer. To load envelopes that are over 7.87 inches (220 mm) in width in the multipurpose feeder, insert the envelopes with the flaps closed and the short-edge of the envelopes facing into the printer. You can load envelopes up to the maximum fill line in the tray at one time. NOTE: Make sure set the envelope flaps are completely unfolded. NOTICE: Never use envelopes with windows, coated linings, or self-stick adhesives. These lead to paper jams and damage to the printer6cf668b.png
Posted on Feb 22, 2008
museumsteve
SOURCE: kodak 5300 wont print on glossy side of photo paper
I just sussed this issue out. On the front of the printer tray there is another pull out tray, this opens up and must activate the photo printing for A4 because it stops the paper falling on the floor once printed (cos once printed on photo paper it may still be wet). As soon as I opened the tray (and it then opens again - you'll see what I mean) it printed A4 photo paper perfectly
Hope this helps others
Posted on Oct 10, 2008
Anonymous
  • 41 Answers
SOURCE: Kodak Easyshare 5100 All-In-One Printer
The Kodak printhead is known to dry out. You can call kodak customer service and complain your printhead is failling explain you have run the printhead cleaning many times waisting your ink. They should ship you a new printhead and free inktanks.
or if you dont want to wait on the phone....
I have found lysol hand wipes to work wonders on the kodak printhead. I have an ESP 5 and I have wiped the printhead with a lysol hand wipe many times and it works like new. Here is a link to the product.
http://lysol.com/products/disinfecting-wipes/dwipes-4-in-1/
To wipe the printhead follow these instuctions.
remove the printhead from the printer. put the tanks back into the printhead. Be very carefull not to drop the printhead and do not put the printhead on a table with the nozzle plate down (where the ink comes out). take the hand wipe fold it a couple times. Gently wipe the printhead nozzel plate in the direction of the lines on the nozzle plate do not do a circular motion or wipe against the grain. you may not even have to use a wiping motion. you can just place the wipe on the nozzles and let the printhead soak. this will clear up dried up ink and unclog the nozzles.
put the printhead back into the printer run one printhead clean once to purge the ink and try to print.
I hope this helps.
I used my printer to do a photo guest book at my sisters wedding it turned out great (i wipped the printhead before i started all the pictures look perfect!)
SDtester.
Posted on Oct 15, 2008
Anonymous
SOURCE: printer fails to feed paper for printing
try gently rubbing the take up roller with a damp cloth - let dry and try with no more than fifteen or twenty sheets of paper in the feed tray
Posted on Nov 03, 2008
Anonymous
SOURCE: Help with my Kodak EasyShare G610 printer
Have you tried cleaning the paper feed rollers with a slightly damp, lint-free cloth? You'll have to remove the paper try first. If that doesn't work you may have to remove the ink cartridge and tighten the roller. I had to call the Kodak technical support to get help with this. Hope this helps.
Posted on Nov 19, 2008
Whydoes my printer keep telling me to load paper?
your paper sensor is either dirty or worn out, try cleaning with canned air or will have to get new printer
Dec 03, 2015 | Kodak EasyShare 5300 All-in-one Printer...
Why does my kodak esp c315 printer keep jamming when I use kodak photo paper
Here is a link to the maual. Be careful about printers. they get dirty fast. The rollers skip and jam up and need to be cleaned. I once found a ribbon in one where a child tried to run it through. If you have had it a while it probally could use a going through.
http://resources.kodak.com/support/pdf/en/manuals/urg01243/C315_AiO_xUG_GLB_en.pdf
Jan 31, 2015 | Kodak ESP C315 Wireless Color Printer with...
Is their anything else I can do to fix the problem?
Go to settings, reset the type of picture and text to be printed. If this doesnt work you can now get a new printer for a great price on Amazon these days.
Jun 12, 2017 | Kodak ESP C315 All-in-One Printer
Kodak ESP C315 Error code 3513 missing print head
Kodak esp c315 .i have the kodak esp c315 and keep getting the printhead loose missing or not installed correctl
Apr 14, 2014 | Office Equipment & Supplies
Kodak c315 not printing red other colours fine tried new cartridges still the same
My KODAK printer was also not printing anything, I tried a lot to fix that but unable to fix. At last I got this link http://www.printer-techsupport.com/Kodak-printer-support.html I just visited and made a call on their toll free. I got instant help from a certified technician to fix my printer.
Mar 01, 2012 | Kodak ESP 3 Multifunction Printer/ Copier/...
Disable paper source kodak esp c315
you can stick the check in letter size using soft adhesiveness tape as paint tape.
print a sample in a plain paper to know the place where you have to stick it...
Nov 15, 2011 | Cameras
My Kodak esp 3200 won't print labels on Avery label pages. WILL print the labels on regular copy paper. Any suggestions on what to do?
I am having the same problem except you didn't address the problem. It's not that the printer prints badly, jams or crashes. The printer literally passes the label paper through the printer and then prints on the next piece of copy paper. I reset my printer not to print the last page first and it still did it. Then I put the label paper second in the feeder. It passed through the first piece of copy paper and the
labels and printed on the third. It's like the printer senses the thicker paper and skips it. My printer is a Kodak ESP C315 and I have no setting for thick paper only plain and photopapers.
Sep 22, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
Warning light keeps flashing
try to remove first all the paper in your paper tray.
then try to remove and then reseat the printhead and both of the ink cartridges.
then after the printer detects your printhead,the message is "New Printhead Detected, calibration require, load paper and press start" it will require you to to do a calibration.
hope this will help
Mark S.
Kodak AIO Technical Support Hotline 1-800-421-6699
Oct 01, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Kodak EASYSHARE G610 Thermal Printer Logo
43 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Ekse
jasbo
jasbo
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
