Kodak EasyShare One Digital Camera Logo
Question about Kodak EasyShare One Digital Camera
Digital camera my digital camera does'nt start, and once it opens it is not closing. i dont know weather it is a battery problem or something else.
Posted by kirthi on
Anonymous
    Champion:
  • 217 Answers
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. you need professional service to fix it.
Posted on Sep 07, 2007
2answers
Garage door opener remote does'nt work when the garage door is shut
Probably you have a weak battery in your remote transmitter. When the garage door is closed it requires a stronger signal. Open the remote and replace the battery.
1helpful
Digital Camera Samsung S760 lens open and close not crooked. beeps twice
My Samsung Camera Lens is Dont Open i dont Know Why .!
i can describe that Thing ..> When im Going to activate The DigitaL camera in Work The Lens is Open in half no at All and do one Noiz like dont have enought Battery But i Charge the battery 5 days to Proveee that in Camera but this thing Didn't Happend
Tell mee why and what can i Do to haveee again My camera :D and to do Photos
My lens won't close
My camera does the same thing. It is getting progressively worse. To get it to work, I have to open the battery door and push the battery a little and finally the camera will turn on and lens will close. Something is wrong with the connection at the terminals and I don't think its something that the owner can easily fix, but at least you can jump start the camera working again. Its just a pain to have to fiddle with it sometimes and it scares me that it might not start again one of these days. If its under warranty get it turned back it quickly.
My camra is stuck open and won't close or take any pictures.
if you did,nt put lithium energizers in camera,thats probably the problem,try that good luck.
Took a picture in cold snowy weather
I have read that weather conditions do affect batteries. If you haven't already done so, might I suggest that you replace or recharge the batteries. Also ensure that you have got the correct batteries as per the camera's user manual.
Failing that, it could well need a visit to the repair shop.
Hope this helps
G
2helpful
My camera won't turn on. It is an older cannon rebel sx (8mp).
I just got off the phone recently with Canon. I explained the problem to them and they stated that it appears it is due to the cold weather. I saw some stuff on these posts about Christmas Time, etc...They said that most of the time the camera will be ok after it thaws out, but some issues can be caused because of this. One of them is total lack of power. They said that the camera I have has a minimum temperature that it can handle of 30 degrees. This can cause the LCD to freeze, can cause short circut problems, etc...Thus leaving your camera totally in-operable.
The technician tried to help me first rule something out. He had me REBOOT the camera....seems odd to do that if there is no power, huh? Here is how I did mine....
Power on the camera....Remove the battery...then the Disk battery....leave the battery door open for one full minute. Now turn the camera off.....put the disk battery in, then the regular battery....close the battery door....power on. If you have power and your LCD monitor goes on it will say something like 00007 or something like that.
Unfortunately.....Mine didnt. So they are sending me info on my email to send in my camera. It will need to be repaired/replace the parts etc...
I hope that your cameras end up working. They guy from Canon suggested that in the cold weather while carrying it, keep it under your shirt close to your body to keep it warm, dont change lenses in the cold air, and if you are photographing an outdoor sporting event and its cold enough for you to be covered up, then do the same for your camera.....he himself wraps a hand towel around his whole camera except the end of the lens and the view finder (the one you put your eye up against, not the LCD) Wrap a rubber band around it to keep it in place on the lens and unit.
So....like i said, please...I hope this helps.
Keep me posted!!! Would love to hear positive things that your camera has started working again.
Julie
Pentax K100D
There is no online diagram you can reference. I would not recommend attampting to open the camera yourself.
If you insist on attempting this, I advise first removing the batteries and leaving it of 24 hours at least. There is no knowing where the high voltage components for the flash unit are, and they will give you a nast electric shock if touched, and if they are accidentelly shorted to any other part of the electronics will destroy the circuitry.
I woud leave this to a photo repair specialist. Preferably your nearest Pentax authorised dealer.
All-weather
The camera loses its weatherproof capability if the battery compartment cover, connector cover or DC-IN jack cover is open. Make sure that all the covers are closed before using the camera. Wipe any water off the camera before changing the battery or card. If the camera gets splashed, wipe the water off as soon as possible with a dry cloth. Salt-water spray or droplets can cause damage to the camera if the camera is not wiped dry as soon as possible. Do not apply excessive force to or attempt to peel off the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover. If the rubber packing becomes worn or damaged, contact your nearest Olympus service center. If the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover contains dirt or sand, wipe it off before closing the cover. The rechargeable battery and other camera accessories are not weatherproof. Care should be taken when using the accessories.
All-weather capability
The following steps can be taken to maintain the all-weather: Make sure that all the covers are closed before using the camera. The camera loses its all-weather capability if the battery compartment cover, connector cover or DC-IN jack cover is open. Wipe any water off the camera before changing the battery or card. If the camera gets splashed, wipe the water off as soon as possible with a dry cloth. Saltwater spray or droplets can cause damage to the camera if the camera is not wiped dry as soon as possible. Do not apply excessive force to or attempt to peel off the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover. If the rubber packing of the battery compartment cover, connector cover or DC-IN jack cover contains dirt or sand, wipe it off before closing the cover. If the rubber packing becomes worn or damaged, contact the nearest Olympus service center to obtain a replacement part.
Slider Prob
Dang, what a weird design. The lens needs to go threw a cycle before it can reach the idle position where it waits for a comand from the user. If its in the closed position and you turn it on it extends to its full range then stops at the idle position. It sounds like it is stuck in some spot between close and idle. Since it cant reach the closed position or idle its shutting down. The only way to get it to work is to try and free the lens so it can cycle threw. There must be a lip on the slider and the lens is stuck on this lip so you cant slide it. Remove the batteries then try and slide the door open try and slide somthing between the lens and the door to free it up. This is the only way to get it threw the cycle. It may need to be serviced It sounds like the switch for the slider door is warn or has broken. It may work again if you can free the lens.
Top Kodak Cameras Experts
Ekse
David Shaub
Are you a Kodak Camera Expert? Answer questions, earn points and help others
