Question about Dell PowerEdge 2600 Server
My dell poweredge 2600 wont load up - Dell PowerEdge 2600 Server
Posted by shawn bloomfield on
hoochiepoos
  • 3 Answers
  1. Can you access the Bios configuration on boot by pressing F2? Check the setting
  2. By load up do you mean your server software does not boot? use F10 on post from the utility partition main menu under Run System Utilities.
  3. Is the server working with RAID? Press CTRL + R and check the RAID
I am not going to say check all the cables because I am sure you will have already?!?
Posted on Nov 01, 2013
3 Related Answers
Anonymous
SOURCE: PowerEdge 2600 does not boot up ?
this server is a compleate wast of time trust me
Posted on Jan 18, 2008
Shawn DuRee
  • 356 Answers
SOURCE: Can I install Windows home sever 2003 on a dell poweredge 2600
I would say yes so long as your server meets theses requirements
Minimum system requirements The following minimum specs are needed:[24]
Additionally, the following are required for installation of the operating system only:
Posted on Apr 16, 2010
Anonymous
  • 91 Answers
SOURCE: Can i change my dell poweredge 2600 server cd rom
Any Dvd Rom should work fine with the server.
Posted on Oct 28, 2010
I'm trying to start Microsoft Windows Server2003 from USB Hard Drive on Dell PowerEdge 2600 Server.
Dell provides lifetime tech support for all PE servers. Call them at 800-945-3355 and give them the service tag or express service code from the server. If it can be done, they will tell you how.
Feb 29, 2012 | Dell PowerEdge 2600 Server
Dell poweredge 2600 wont load anything from hard-drives what do i do?
Go into CTRL-M, go to Configure>View/Add, accept and save Disk View if prompted, and check the status of each drive. What is your RAID configuration (F3) and the drive statuses? If you are in the States, call Dell support 8008228965 - it is free whether in or out of warranty. It will be much easier to explain what you see.
Mar 14, 2010 | Dell PowerEdge 2600 Server
XP cannot find disk
If you are installing this on a PowerEdge 2600, you will have difficulty installing XP, as this is a server and drivers will be scarce, not the least of which will be the RAID controller (PERC 4/Di). If you had it, you would need to load the driver at the F6 prompt just after booting to the Windows disk.
Jan 05, 2010 | Dell PowerEdge 2600 Server
Drive Options with a Dell Poweredge 2600
I would definitively not recommend to remove the backplates, unless you want to ask for serious trouble with your system.
I would install a PCI SATA adapter card (one like these) and connect your SATA drives to it.
May 27, 2009 | Dell PowerEdge 2600 Server
DELL Poweredge 2600
The Dell original standard CD drive shipped with the PE2600 is incapable of 'understanding' the latest generation of bootable CD's (no matter what the BIOS says).
As far as I can tell, it's not fixable in the firmware ..
However you can swap it out for a more modern drive - such as the TS-L462C (which is a plug in replacement combined DVD reader / CD reader/writer - and Dell post the required drivers on their PE 2600 web pages, so I assume it must be a 'supported' solution)
Jan 18, 2009 | Dell PowerEdge 2600 Server
CAN YOU TELL ME HOW TO GET WINDOWS XP TO LOAD ON THE DELL 2600 POWEREDGE SERVER IT ONLY OFFERS SERVER 2000 AND SERVER 2003 AND I CANT USE EITHER OF THEM THANKS MIKE
Hi tham01,
First off, if the server has raid already setup, you will need to go into lsi logic to format the drives so you can install XP. Once the drives have been initiated from the server bios, just place XP in the CDROM, and shouldn't have a problem loading on the 2600 POWEREDGE SERVER. If your trying to install it with the Dell quick install disk, you can't!!! Install it on it's own without the Dell Disk.
Good Luck!
Mark
Jan 13, 2009 | Computers & Internet
DELL Poweredge 2600 Bios FREEZES After Cpu check and before SCSI Drives check HELP!!!!
The BIOS check can freeze for many reasons.
Can you tell me if this is an existing system that was working fine and then had this problem, or is this a new (or new to you) system?
Can you give more information on what is actually showing on the screen?
Nov 05, 2008 | Dell PowerEdge 2600 Server
Dell PowerEdge 2600 Server Logo
137 people viewed this question
Lee Hodgson
Lee Hodgson
efs_perpends
efs_perpends
Michael Thomas
Michael Thomas
