SOURCE: Daihatsu Mira 3 cyl 660cc No
In my past dealings with these 3 cylinder engines, common faults (depending on the engine) are:
Please check above mentioned components.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
SOURCE: daihatsu mira
I have a 1992 daihatsu mira the fan will on turn on if I have the air con on is that correct. So if its over heating I need to turn the air con on to turn the fan on!
