Question about Motorola Mag One BPR40 Two Way Radio
Have two bpr40 need to find out the frequencys
Posted by rodger on
eradiostore
  • Motorola Master
  • 1,658 Answers
The BPR40 is a dealer programmable radio. The frequencies would need to be read out using Motorola proprietary software. The only thing you can tell from looking at the radio is whether it is VHF or UHF. Model number AAH84K... is VHF and AAH84R... is UHF.
Best regards.
Posted on Aug 21, 2013
Is motorola cls-1110 compatible with bpr40 radios
yes, with conditions. The CLS comes preprogrammed with frequencies and tone codes. The BPR requires software and cables. It is not a preprogrammed business radio, but a fully programmable business radio. If your BPR radios are first: UHF, then they can be programmed to match the CLS. Do note, a few of the CLS frequencies are approved by the FCC for low power only, meaning a maximum of 2 watt power output. Find a dealer willing to do the programming for you if you do not understand. Our shop does it often.
Mar 14, 2015 | Motorola CLS 1110 (1 Channel) 2-Way Radio
How to I syncronize all my radios so they work together
Karen-
Contact Motorola Solutions
Get Support
Mark
Motorola Mobility Support
Jan 09, 2015 | Motorola 4 Magone Bpr40 Uhf
How do you synch a set of Motorola MagOne BPR40 radios to a new set of the same radios?
BPR40 radios are dealer programmable using Motorola proprietary software and cable.
Jun 23, 2014 | Motorola Mag One BPR40 Two Way Radio
Radio Tuning
That radio is easily programmable for other, or additional frequencies in the same band. I believe (I've been out of the business for a while) you need a special computer interface and software in order to affect a change. I'd contact a Motorola shop. You will also need to be licenced for the new frequency. I hope this helps.
Mar 31, 2014 | Motorola Mag One BPR40 Two Way Radio
How do i remove the circuit board in the BPR40
PeteD.
Contact Motorola Solutions.
Get Support
Mark
Mar 13, 2014 | Motorola Headset Mic Vl130 Pr400 Bpr40...
Can a RDM2080D pair with a BPR40?
If your BPR40s are VHF (model number beginning AAH84K), the answer is yes. The BPR40s can be reprogrammed to match your new RDM2080D VHF MURS radios. This can be done by an authorized Motorola dealer with a current software subscription. (If you cannot find a dealer, look us up online, we will be happy to assist.)
You might want to consider keeping your BPR40s around. The BPR40 has a more economical battery replacement cost (under $35), and is repairable/recondition. (currently $69 flat rate)
Your BPR40s are also capable of more wattage than the RDM2080, 5 watts vs. 2 watts. However, it should be noted the BPR40s will need to be programmed to the lower wattage when going to the MURS frequencies.
Best regards.
Jan 22, 2014 | Motorola rdm2080bfaas rdm2080d 8ch murs...
I have 6 gp328 and my multi charger power supply burned i guess due to the variying of frequency, can i use diffrent power supply with the same output voltage of the burned power supply?
yes you can. So long as voltage is the same. Replacement power supply runs about $120.00. Also make sure replacement power supply has the same current capabilities as original
Apr 15, 2012 | Motorola Mag One BPR40 Two Way Radio
How do I connect Mag One BPR40 two way radio by Motorola to CP100 two way radio by Motorola? I already had about 8 CP100's and we just got 2 new Mag One's. Thanks.
The Mag One BPR40 is dealer programmable. You have two choices:
1) Reprogram your CP100s to match the new BPR40s. For this you would need to know what the dealer programmed the BPR40s to... OR
2) Take your BPR40s back to the place of purchase and request they reprogram them to match your CP100s. This should be a free service since you just purchased the BPR40s. They will need to know some settings from the CP100s to make the match.
Best regards.
Sep 17, 2011 | Motorola Mag One BPR40 Two Way Radio
We purchasedn 3 bpr 40 and we justed ordered another, when we turn the bpr on to the channel of the 3 others that are in use, we just get a low continual tone, i tried a radio check on channel 1 with no...
Your new radio is likely not programmed the same as the others. A continual tone indicates a channel which is not programmed (doesn't have a frequency installed).
The other thing which can cause a tone, is a low or uncharged battery. You might try switching one of the known good batteries to the new radio to see if it will work. If you still have the same continual tone with a known good battery installed, you have a programming issue. If the battery swap solves the problem, then you need to investigate why your battery isn't charged up.
Either way, contact the dealer where you purchased the BPR40, they should provide programming free, or a warranty replacement battery for free. If you ordered online or by mail, and you just received the radio within the week, you should request they provide return shipping for you.
Best regards.
Sep 14, 2011 | Motorola Mag One BPR40 Two Way Radio
Bought a used Motorloa Mag One BPR40 at a tag sale and then bought a new one. The used one looks like it was used by a business so it was probably "programmed." How do i get the two BPR's...
Your radios will need to be programmed by a Motorola dealer to match one another. (Usually $15-$25.) The software used to program the radios is a Motorola proprietary software and not for sale, but most dealers have a subscription to it.
The loud buzzing indicates the channel you are on is not programmed.
Best regards.
Aug 10, 2011 | Motorola Mag One BPR40 Two Way Radio
Motorola Mag One BPR40 Two Way Radio Logo
162 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Anthony Ward
Anthony Ward
Ekse
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
