Firewire hd not showing up in profiler or diskutility on imac gr
Hello! You know how to take off the HDD from its casing?
okay, No. 1 error is due to loose of connections. All you have to do is to dismantle it. And be sure to memorized where its original position.
You need to set the jumper settings of your HDD to master.
next, be sure all the connections are intact and well connected, then assemble it again.
next, be sure you are using Power Mac g4 CPU 1.2Ghz with at least 1GB of memory or Higher than G4 units, cause 300GB couldn't be detected lower than that, then plug it in.
if it still didn't work out, try to ask help from service center near you to assist you.
