Thromo stat bad the tempature knob has a gas valve attached to it along with two gas lines you will have to remove the oven to acess all lines as they run on the backside of the case remove the burners and gas input line copper line remove gas supply tube to all burners remove valve and take to dealer they need the numbers off the vavle for exact repacement not just the numbers off the stove itself east fix with simpl hand tools thermost has a themocouple attached to burner assembly and this is your problem bad part is themocouple is built into thermostat and is no serviceable only fix is to replace "thermostic gas valve"
