SOURCE: Incompatible JPEG format
you are most probably looking at the pictures from the camera screen.... if you use a CF card reader and view them on the PC through internet explorer or any other software they will be fine..
You get this error when the files have been changed on the CF card by anything aside from the camera
SOURCE: setting RAW as file format
Make sure that the mode dial is not set to one of the 'Basic Zones', i.e. Auto, Portrait, Landscape, etc. You should be able to select RAW or RAW+L in P, Tv, Av, M, or A-DEP.
SOURCE: My new canon rebel T2i/EOS
A 5 error is the camera thinks the flash is not raising. Look near the hinge for a small button and see if it is up or down. This lets the camera know is the flash is up or down and if the button is stuck down you will hear the motor fire a few times and it will then error.
Unfortunately, this is one of the problems that starts to appear on cameras with pop-up flashes. You can hit the button and pull it up at the same time. Only other option is to send it to Canon to get it repaired.
or, Get an Speedlite like the 430EXII or 580EXII. The flash unit may make your camera bigger, but the results will be much better once you learn flash techniques.
