Question about Frigidaire Ovens
Frigidaire fe50s8w oven not working but elements testok
Posted by mitchell cannon on
5 Related Answers
Anonymous
  • 145 Answers
SOURCE: Frigidaire Double oven PLEB30T8AC
The best way for you to check is to swap with other element since they use the same one. FRIST turn the breaker off! Then take out the 2 screws on the element. The wires unplug, make sure they don't go back in the holes or the oven may have to come out to find them. You can pull the element out and take it to a parts house to see if they can check it with a ohm meter for you if you don't want to pull both of them out.
Posted on Apr 18, 2008
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Frigidaire double oven has one element not working in each oven
sounds as if perhaps there has been a thermal overload(switch) tha has gone bad, refer to part number 119 on bothe the lower and upper oven for refernce , you should have continuity trough the switches.
ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995383394.pdf
Posted on Dec 21, 2008
Anonymous
  • 20 Answers
SOURCE: Element in top oven not heating up all the way.
Yes needs a new element.they burn out. easily.you know this because they sell them seperately.its there way to make money off of you.anytime they sell you something and the parts are readily available especially sold seperately you know its going to need to be replaced eventually..If you replace 1 replace them all to avoid furthur issues.
Posted on May 29, 2009
Anonymous
  • 135 Answers
SOURCE: frigidaire wall oven will not heat up very fast
The clock control has a relay that turns on the element. It could be failed and would require a new clock control.
Posted on Aug 27, 2009
Anonymous
SOURCE: model FEFL78CBC frigidaire oven bottom (bake)
We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
Posted on Mar 16, 2010
Frigidaire Gallery oven large element stopped working
Hello -
If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works, contact a professional to have the EOC (electronic oven control) diagnosed.
Sep 19, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire oven not heating
In the oven, does the heating element and the broil element not work, or is it just one? You might just have a bad element, or a bad control board.
Jul 30, 2012 | Frigidaire Ovens
Frigidaire DGES388DS2 electric single oven
Did you reset the house circuit breaker that supplies power to the oven?
Apr 24, 2012 | Frigidaire Ovens
I have a frigidaire 30" wall oven GLEB30T8CBA.
The control on the upper bake element has failed.and needs to be replaced
Nov 28, 2010 | Frigidaire 30" Built-In Double Electric...
My frigidaire oven won't heat. The burners work
You have two elements turn on the broil and see if the top element comes on if it does replace the bottom element.
Aug 23, 2009 | Frigidaire Ovens
Frigidaire Caprice Oven won't work
i have a double caprice oven and the top oven wont go - something to do with timers
can u help
May 12, 2009 | Frigidaire FEB27S5A Electric Single Oven
Nov 24, 2008 | Frigidaire GLEB30T8A Electric Double Oven
Frigidaire GM deluxe electri dean (electric oven wall unit)
if you feel through the insulation you can find the two wires that attach to the element pull them through to plug the element back on but there is no plug per say but first are you sure the element is good were there no wires on the element when you removed it should have been two spade connectors with wires on them attached to the element hold my rating till you reply
Jan 11, 2008 | Frigidaire FEB27S5A Electric Single Oven
Ovens Logo
35 people viewed this question
Top Frigidaire Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Paul Carew
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
