I have a verison wireless usb mobile broadband card and a linksys wrt150n router. I need to connect the usb modem through my desktop computer and then I want to run out of the ethernet wire to the router to have wireless without buying the expensive router from them. I need help setting up the router to give off the wireless. Thanks for any help!
First thing that you have to do is to check if the wireless light on your linksys wrt150N is lit. If it is, then that means that it is emitting wireless signal so you can connect wirelessly.
Then, install your verizon usb mobile broadband card on your desktop. When you plug it to the usb port, a pop up balloon would show on your page which would say FOUND NEW HARDWARE. you could click on it and choose the CD-drive to install OR you can run the cd and have it install on itself.
After installing the usb, try to connect to your wireless network. Start > Connect to > and then click on the name of your wireless network.
do you have a Wireless Router + Broadband modem?
This is like a base station to which your remote wireless node communicates (to get connected to your home network and internet.
something like this http://catalog.belkin.com/IWCatProductPage.process?Product_Id=187337 for an ADSL connection.
If you are on cable, you can either get a Router similar to the one above (but for cable) http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1138056788757&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=8875739789B01
or if your Cable modem has LAN ports you may just be able to use an "Access Point" to add Wireless capabilities. http://www.linksys.com/servlet/Satellite?c=L_Product_C2&childpagename=US%2FLayout&cid=1126536803676&pagename=Linksys%2FCommon%2FVisitorWrapper&lid=0367639789B22
I am not sure what that is. I need to be able to connect the desktop computer to the router with the internet coming from the desktop. The broadband card has software to connect it so it must be connected through the desktop and then I would like to have wireless. Hope this helps!
Yes I have done all this. I have ran into the problem of the internet not connecting to the router. The router has a wireless field but the wireless has no internet connectivity. I need the help setting the setting on the router and computer so that they can connect to each other. Hope this helps!
Are you trying to bridge a modem to the router?
