Question about Frigidaire ATF6000ES Front Load Washer
Part way through the wash the machine stops and beeps. Err 10 flashes on the little screen. I try to pause/cancel to start it again. It will go through about twenty minutes of the cycle and the same thing happens.
The E10 error indicates a long fill error meaning the machine thinks it took to long to fill with water.
We recommend u to check that the drain tube is now stuck to far into the stand pipe and possible causing as siphoning problem, and that the screens on the water valve inlet are cleaned and not slowing the water flow.
u can hook the drain hose off, forcethe water through it with a water hose, unclog the stinky mess and hook it back up again and work it.. tat woul do..
Plz rate this solution.. thank you..
Posted on Apr 08, 2009
May 13, 2014 | Zanussi ZWD1470W Front Load Washer / Dryer
Dec 09, 2013 | Hoover AI130 Front Load Washer
Jan 17, 2010 | Washing Machines
Apr 22, 2009 | Frigidaire Affinity ATF7000E Front Load...
Dec 12, 2008 | Frigidaire ATF6000ES Front Load Washer
Dec 10, 2007 | Zanussi FJS1225W Front Load Washer
Nov 20, 2007 | Kenmore Energy Star 44092 Front Load...
Nov 16, 2007 | Frigidaire Affinity ATF7000E Front Load...
Nov 15, 2007 | Frigidaire Affinity ATF7000E Front Load...
Nov 13, 2007 | Frigidaire GLTF2940ES Front Load Washer
195 people viewed this question
Thank you!
