Will not turn over, been fairly hard to start since i purchased, company said it needs an adjustment but wants to charge me, says it is internal, can i do this myself?
Sure. (This will void your warranty and bypass smog requirements!) There is a red and a white limiter cap on the carburetor adjustment screws. Red= High speed / White = Low speed. Remove limiter caps. Turn both jets a 1/2 turn counter clockwise, Start, then fine tune. Use the low speed and idle screws to smooth out low to idle speed and the hi speed jet to tune the full throttle.
If this blower is left with gas for any length of time.. check the fuel lines and primer button before messing with the limiters. The methanol in the gas is eating up the lines and primer which is letting excessive air into the sytem making it run rough.
Cut them off. I use a Dremel tool with a cutter used for plastic.
How do i get the caps off?
how do i remove the limiter caps on the jet settings
