Our water was shut off briefly at the main. When we attempted to run the dishwasher, no water is drawn into the machine. All the panel lights work, just no water. Turned the water valve off and on several times, with and without the water running. Still nothing. Any ideas?
The most common reason for this problem is the inlet valve (Solinoid valve) has failed and does not open when the DW timer tells it to before each wash and rinse cycle.
That valve is just inside the place where the hot water supply hose connects to the dishwasher.
There can be other causes but this is by far the most common reason.
Good Luck!
same as above
