Question about Gold Medal 2086 Popcorn Maker
I have a Gold Medal Popcorn Machine 2086. The kettle is uncleanable. Where can I purchase a new Kettle?
Posted by etarver on
gary anderson
    New Friend:
  • 4 Answers
You can get the inner part of the kettle for under 75 bucks. a new popper is in the $500 range.
Posted on Jul 13, 2012
Anonymous
I hate to put this as a solution because it really isn't. I have an old popper needing a new kettle and was told it was almost as much to purchase a new kettle than the whole machine. The kettle is almost the entire cost of the unit. I will be purchasing a new unit.
Posted on Jun 23, 2009
Why is my gold medal popcorn model # 2552 machine not heating to pop popcorn anymore?
A kettle not heating is either a switch, kettle wires, thermostat, or kettle heater.
Check that the kettle is plugged in tight, notice if the switch lights up when switched, then contact your local gold medal dealer for repairs. It is always cheaper to repair a gold medal kettle than replace.
http://www.gmpopcorn.com/domestic-dealers.cfm
Oct 01, 2014 | Gold Medal Kitchen Appliances - Others
Gold Medal Deluxe Pinto Pop Popcorn Machine Model 2147 will not heat up
If the switch is OK and you have. Power at the kettle plug and you are not getting any heat it's one of 3 things. Burned wire inside the kettle. this is common. Or it could be the thermostat is bad or the element itself is out?
May 07, 2014 | Gold Medal Products Gold Medal 2147 120208...
How to install a stir rod in a Gold Medal Product, Deluxe Pinto Pop, model 2147
Take the kettle crossbar assy off the kettle and look and see if there is a set collar above the shaft weight. If so loosen it so you can slide the weight up...enough to get the old one out and the new one in.
Mar 31, 2014 | Gold Medal Products Gold Medal 2147 120208...
New kettle for the gay 902 whiz bang popper
Yes you can purchase new kettles complete or just the bottom half most of the time with the gold medal brand. When you see the prices you may want to consider repairing or rebuilding it. That's what I do unless there are so many parst needed that a new one would make more sense because I believe you will get a warranty with the complete kettle?
Feb 04, 2014 | Gold Medal 2003 Whiz Bang Popcorn Maker
I need parts for Gold Medal Bronco Pop 2152
What is the age of the machine? or if you can post a picture of the Kettle itself I should be able to help you out.
Nov 24, 2012 | Gold Medal 2152 Bronco Popcorn Maker
8 oz kettle does not heat would like to price replacement kettle
try this link
http://www.vendingmachinesworldwide.com/gold-medal-2014-***-90s-whiz-bang-popcorn-machine-kettle-receptacle-replacement-part-gm49330.aspx
hope this helps
if its not the part you require email them ,
there really good
VendingMachinesWorldwide.com, Worldwide Markets, LLC
2630 Ladue Cove
Fort Wayne, IN 46804
Email us for all inquiries
[email protected]
hope this helps , if it does please vote
Nov 09, 2009 | Gold Medal 2131 Antique Gay 90s Pinto Pop...
Need model number for Gold Medal popper
http://www.concessionpalace.com/concession-tutorials/P-60_60_Special_Uncle_Walts-1866_2085_2086_2656-popcorn-machines.pdf
Sep 01, 2009 | Gold Medal Kitchen Appliances - Others
Trips circuit when you turn on the Kettle heat
When the fuse blows see what else in the house is out, maybe you have the circuit overloaded. Try putting the popcorn maker on a different unused curcuit to see if it still blows. Then you will know if it is the popcorn maker.
Dec 09, 2008 | Gold Medal 2086 Popcorn Maker
Heating element
What size kettle?
It is probably the thermostat
Oct 31, 2007 | Gold Medal 2086 Popcorn Maker
Gold Medal 2086 Popcorn Maker Logo
710 people viewed this question
Top Gold Medal Kitchen Appliances - Others Experts
Adavoid
Level 1 Expert
john h
Tom Chichester
Are you a Gold Medal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
