A needs a fan speed switch
SOURCE: Hunter ceiling fan-just installed -possible speed control problem
Sounds like the fan is defective. All internal wiring from the switch to the motor is factory installed. The fan has power going to it. Just to make sure, double check the wiring from the ceiling fixture to the fan.
Problem could be a faulty switch on the fan or faulty motor(bad winding for med. speed). Try reverse switch on the fan to operate the opposite direction and see if medium speed works. If medium does work in opposite direction, it pretty much points to a defective fan. In any case, unless you discover that the ceiling wires were reversed going into the fan, I'd say new fan to the returns dept.
SOURCE: I have a hunter ceiling fan (model #20537) which
Check with stores that sold it and see if they will warranty replacement. I think there is a lifetime warranty, thats why you pay the big bucks for the Hunter name.
SOURCE: need the manual for our ceiling fan, Hunter, Park
i have to fans close to each other i would like to change the code on the remote
SOURCE: I replaced the 3 speed fan switch on my Hunter
What was the original reason why you changed the switch? Sounds like you got the hot wire and high speed wire swapped. The hot wire coming from the upper part of the fan should go to 'L' and then the three other wires going down to the little black boxes for the speeds should go to the corresponding 1,2,3 on the switch.
