I have a dishwasher model number PLD2851RDC3. They 3rd level spray arm keeps falling off. It appears the white plastic delivery tube is the problem. This is the small piece that fits in between the circular plastic piece and the spray arm.
Can I just get the plastic tube or do I have to buy the entire spray arm (part 24B, 154478201)? And if I buy the part 24b, does it come with all 3 parts (the round plastic piece that screws into the top of the dishwasher, the delivery tube and spray arm)?
Thanks.
SOURCE: The top spray arm of
Hello there:
hey sorry i keep getting disconnected i will be back on really soon i need to find out what is going on i hope these things that i have discussed with you is helping you out the parts are not as hard as they look once you getthenew part it will have theinstallation instructions ok
Best regards michael
SOURCE: upper spray arm falls off during operation, even after snapping
the clips that hold it in place are worn. you will have to replace it. they are not very expensive. to remove it simply unscrew the round disc above the arm
Testimonial: "Wish one could buy just the clip and not the whole assembly, but it is not expensive."
SOURCE: upper spray arm failure
Easy to solve!
(1) Remove the drawers to give yourself room to work
(a) bottom drawer just comes right out -- but you knew that
(b) Carefully unclip small plastic retainer caps at the ends of the metal "glides" for the top drawer. Then slide the caps out of the glides. Then remove the top drawer.
(2) Unscrew the "gear-like" plastic fitting into whose hole you were sticking your finger when you felt that small cylindrical ring.
(3) Now that you've got access to the ring, the solution is obvious -- use it to snap the upper arm back into the gear-like fitting. When you're done, the arm will rotate freely in the fitting.
(4) Put everything back together and enjoy the fact that you didn't have to pay some yobbo $75 to come to your hous and do this for you!
(HINT: When screwing the gear-like fitting back into place, use the old machinist's trick of pressing gently and screwing backwards until you feel a click. The threads will now be aligned for you to screw things together the right way. If you do not do this, you might experience frustration reattaching fitting -- since the piece it screws onto is spring loaded.)
